CPP can you answer some questions please - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > This is a list of our Official Sponsors , Quality 55-56-57 parts Click Here > Classic Performance Products
User Name
Password
Classic Performance Products This special area of the Forum belongs to Classic Performance Products, Members can ask questions and get answers about Classic Performance Products, parts and policies, and get free Tech support about Classic Performance Products only. Post about any other company’s products or services will be deleted if posted in this forum
Parts on Ebay
Reply
Thread Tools Display Modes
Old 10-11-2018, 03:39 PM   #1
rjabianchi
Member
Member #38615
Default CPP can you answer some questions please
Default Front Suspention Advice
I am currently doing complete ground up on 55 210 post.
Will be putting an LS3 and 4L80E trans
Here is what I think would like to do , All opinions will be highly valued.
CPP Upper and lower Totally Tubular A-arms #5557 TCA-UKB and
#5557 TCA-LKB
500 series steering box-will this work with spindle ?
New CPP Corvette style spindles -CP30019 --What is offset ?
Corvette Hubs -CP35036 --What Wilwood Brake kit works with this ?
Coil-over shocks Brand and spring rate ?
rjabianchi is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-11-2018, 03:53 PM   #2
hotrodg726
Trifive Leaders Club
hotrodg726 has made a donation to the forum!
hotrodg726's Avatar
Member #12165
Default
CPP is the last place I would be asking this advise from. Hieghts would be a much better choice with much better support
__________________
hotrodg726 is online now   Reply With Quote
Old 10-11-2018, 05:40 PM   #3
SLIM
Senior Member 2 Gold Stars
SLIM's Avatar
Member #18096
Default
Quote:
SLIM is offline   Reply With Quote
Old 10-11-2018, 07:32 PM   #4
glide12
Senior Member
Member #32931
Default
Well, you probably won't find much info here other than the usual CPP bashing!
With that being said, It's too bad they don't list the complete spindle/C5 big brake kit for the Tri-fives like they do for some other models. That 30019 spindle utilizes the C5 Corvette bearing, rotors and calipers so any factory, Wilwood or Baer brakes for a C5 Corvette should work. You'll have to call to verify, but I would imagine those spindles keep the original drum brake offset.
I bought the complete tall C5 spindle/brake/bearing/hose package for my 67 Camaro. Everything bolted up perfectly and it was a huge improvement in braking and handling over the original 11" four piston disc brakes. That setup kept original wheel offset.
The 500 steering box, some tubular arms (not necessarily CPP), the C5 spindle/brake kit, some coilovers and a front sway bar should make a Tri Five stop, steer and corner pretty good.
I don't have my 55 back together yet, but I just used some QA1 coilovers and I think 400# springs. I would have to check. I went with whatever was recommended for the 55 and the Camaro, but in hindsight, I think another 50 to 100 pounds more spring rate might be better.
glide12 is offline   Reply With Quote
Old 10-11-2018, 10:48 PM   #5
Rick_L
Member #2256
Default
OK I'm going to bash.
CPP sells some stuff that doesn't live up to expectations. The pitman arm debacle was even worse as this is a safety item. Same with some of their steering columns. Their customer service sucks.
Even if/when they have a viable product, the online information on it is lacking. I don't know if these spindles are worth having but the lack of information tells me to look elsewhere because of their other products.
Rick_L is online now   Reply With Quote
Old 10-11-2018, 11:58 PM   #6
glide12
Senior Member
Member #32931
Default
Yes, the pitman arm debacle was not a shining moment for CPP, but it's not like every pitman arm and every part they sold was bad. When customers want parts as cheap as possible, and you sublet the manufacturing overseas, things are bound to go sideways at times.
I think it's been pointed out many times that there is nothing wrong with CPP's tilt steering column. It's the same design GM has used for years.
Old 10-12-2018, 12:14 AM   #7
BamaNomad
BamaNomad's Avatar
Member #31544
Default
Quote:
THAT is NOT what the NZ and Aussie safety agency says!! I don't know where you got your information??? What they said is that CPP produced and other chinese produced tilt columns do not use a 'fail safe' design in their tilt columns as do GM and all American mfgs...
__________________
BamaNomad(er)
'55, '56, '57 Nomads
North Alabama area
Gary
BamaNomad is online now   Reply With Quote
Old 10-12-2018, 01:14 AM   #8
glide12
Senior Member
Member #32931
Default
Quote:
Unlike some of the other Chinese tilt columns, the CPP column has the same "fail safe" double yoke design as a GM column. That's a fact. There was a picture of the CPP shaft in that report from 2013.
I'm not going to argue about it, because I don't care. I've got an Ididit column in my 55.
Old 10-12-2018, 01:27 AM   #9
SLIM
SLIM's Avatar
Member #18096
Default
[QUOTE=glide12;2130284
I'm not going to argue about it, because I don't care. [/QUOTE]
Could have fooled me
Old 10-12-2018, 04:02 PM   #10
hotrodg726
hotrodg726's Avatar
Member #12165
Default
the cpp column is a POS let me repeat that POS. it is sloppy has scraping parts inside and in general is made poorly. I know this from experience with using them when customers brought them to me for install then Complained LOUDLY about what a cheap POS they are.
__________________
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
