Bad PV-2 Porportioning Valves
1K views 2 replies 3 participants last post by  USA1
#1 ·
Last week I returned a brass PV-2 valve as the rear port would not bleed. The second valve also would not allow brake fluid through rear port of valve. I finally put the rear internals from my old PV-2 in the new valve to get it to work. Maybe CPP has a bad batch of valves....I couldn't even blow air through the rear inlet unless I loosened rear section of valve.
Yes, both valves were "centered" ...
I certainly learned a lot more about P Valves than I really wanted. So maybe it was a good thing
Ace
