Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Trifive Nomads, Sedan Deliveries and Station Wagons
Trifive Nomads, Sedan Deliveries and Station Wagons Trifive Nomads, Sedan Deliveries and Station Wagons Discussion, 55-56-57 Ask your Questions or help others with answers. Or any general Talk about Trifive Nomads
Old 07-28-2017, 02:06 PM   #1
Wayne Meuir
Wayne Meuir has made a donation to the forum!
Member #26332
Default Gas tank relocation ?
I have the body of my 57 Handyman off the frame right now doing some work on the frame/suspension.
I plan to center the tank and remove the spare tire well. Is it safe to cut the spare well out with the body off the frame or do I need to wait until I get it back on the frame? It looks to me that the spare tire well adds very little rigidity, just need opinions from those who might have done this.
Wayne
Wayne Meuir is offline   Reply With Quote
Old 07-28-2017, 03:33 PM   #2
No problem with cutting the spare well out now - as you speculate, it doesn't do much if anything for rigidity of the body. It's OK to weld in your flat patch now too.
Old 07-28-2017, 06:59 PM   #3
Wayne Meuir
Member #26332
Thank You, Sir. I was pretty sure it would be OK.
Wayne
Old 07-29-2017, 10:56 PM   #4
asbicca
asbicca has made a donation to the forum!
asbicca's Avatar
Member #2624
A wagon or Nomad tank is already centered. You can remove the spare tire well and put in a tank from a sedan but you loose a gallon of capacity. The only reason to remove a wagon tank would be for suspension changes or a larger custom tank will larger capacity.
asbicca is offline   Reply With Quote
Old 08-01-2017, 06:36 PM   #5
Wayne Meuir
Member #26332
I have the spare tire well out. Only about 50 spot welds I had to drill out.
I have a Dana 36 out of a 96 Vette that I think I am going to install. The stock rear end in this car needs a lot of work, so installing the Vette rear probably won't be much harder than rebuilding the old one or installing a 9" Ford and I get better brakes and IRS.
I have spent the last two days scraping the crappy undercoat off the bottom of the floor pan and I am still not even half done. Once I get that done I will install a flat panel where the spare tire well used to be and then spray epoxy primer on the entire bottom of the car.
Wayne
Old 08-01-2017, 07:17 PM   #6
zookpr
Member #4323
Wayne
Unless you are going to use the original tank you should create some new supports for a passenger tank or aftermarket passenger tank. The above tanks are narrower and increase exhaust room.
zookpr is offline   Reply With Quote
Old 08-01-2017, 07:25 PM   #7
Wayne Meuir
Member #26332
I already bought an Earl Wiliams tank relocation kit. Pretty expensive for what it is, but it is a really quality piece.
If I do use the C4 rear end, I will probably have to buy an aftermarket tank in order to clear the sway bar if I mount the sway bar on top of the frame. I don't really want to mount the sway bar forward because it sits too low to the ground mounted that way.
Wayne
Old 08-11-2017, 10:22 PM   #8
Dan the 57 man
Dan the 57 man's Avatar
Member #44662
Default 57 wagon fuel tank
I removed my stock tank and tire well also. I felt I needed a larger tank and wanted an upgrade. At the time a few years ago there wasn't an afordable option. I purchased a 22 gallon plastic fuel tank and built my own hangers, and cut a 5 inch hole and home made plate to fit so I could put the pickup tube and sending unit through the 5 inch aluminum plate cover. It fits nicely.
I am considering a high polish stainless cover for the bottom and sides.
Dan the 57 man is offline   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
