Old 10-19-2015, 10:45 PM   #41
primer55
Member #37188
Default rear end help and questions
All this info is great, and a little overwhelming, but I have a question... I talked to a guy locally who does ford 9' rears for any car/truck, and he mentioned something about the "offset"?? I'm a little puzzled and he won't explain unless I buy from him, but I'm not ready to buy until I have all the info I feel I need. Is there a GM rear that will fit(I can weld new perches if nesc.) my quarters are cut gasser-style, and I'm looking at running either 8.5 or 10" wide rear wheels, I don't want them sticking out but even with the quarters looks good, to me anyway. Any help would be appreciated, thanks. PS, I'm on a pretty tight budget!!
primer55 is offline   Reply With Quote
Old 10-20-2015, 01:43 AM   #42
duke57
duke57's Avatar
Member #7459
By "offset" I think he means the axle tubes are not even. If someone is not willing to explain to me upfront a question I have, I typically don't do business with them. I bought my 9" from Quick Performance a sponsor hear.
http://www.quickperformance.com/
They answered all my question told me of options (10 or 12 bolt) and sent me my rear in pieces which were all bolt together. The center section & gears were one unit ready to be bolted onto housing. Perches were welded on and they will make it stock or narrow width.
♫♪Duke♪♫
My build thread: http://www.trifive.com/forums/showthread.php?t=132120
Photos of my garage build: http://www.trifive.com/forums/album.php?albumid=4604
My car 86 - 2011
duke57 is offline   Reply With Quote
Old 10-20-2015, 09:43 AM   #43
NickP
NickP's Avatar
Member #2134
OFFSET; regarding ANY rear axle assembly but pertaining to a 9" as discussed, means the distance from the face of the axle flange to the face of the bearing housing end. Ford has a list of three that are common and an occasional odd ball. Std. Dims are as follows - 2.5, 2.36, 2.25 and (Oddball) 2.00 Looking at the image below, "G" is the offset distance and will have a place in your build when it comes to supplying/ordering rear brake systems, regardless of drum or disc. Each, unless changed by the PO, is determined by YOM and application.
“Luck is what happens when preparation meets opportunity.”
NickP is online now   Reply With Quote
Old 10-20-2015, 01:25 PM   #44
duke57
duke57's Avatar
Member #7459
Thanks for the correction Nick. Very nice explanation & diagram
♫♪Duke♪♫
My car 86 - 2011
Old 03-16-2016, 10:25 AM   #45
bsa_bob
bsa_bob's Avatar
Member #19942
thats it Terry thank you for the quick reply . I now go to the copier great day to you bob s
55 chevy 2-dr sedan. slow build -I ain't 60 anymore
bsa_bob is offline   Reply With Quote
Old 03-20-2017, 08:14 PM   #46
fordkh
Member #43827
ok, i have read the posts, what is an easy swap width wise, i don't care about brackets/mounting, just width, also needs to be chevy
fordkh is offline   Reply With Quote
Old 03-20-2017, 09:04 PM   #47
NickP
NickP's Avatar
Member #2134
Width to task, that, is the question. In other words, what is the plan? Stock appearance, modified, gasser, canyon carver, pro street and so on. Again, width to task. Tires? Stock, 275, 295, 300, 315 or 345 and bigger.
The variables to task are numerous. In other words - Not enough info.
Old 03-21-2017, 10:28 AM   #48
USA1
Member #6974
57-58 Olds. Pontiac 9.3
67-69 Camaro 10 or 12 bolt
68-74 Nova 10 or 12 bolt
64-67 Chevelle 10 or 12 bolt
All GM 60 wide like stock and as strong as stock or better
USA1 is offline   Reply With Quote
Old 03-21-2017, 12:10 PM   #49
JT56
JT56's Avatar
Member #2404
Default Rear end Width
What are you're plans for the car? Tire width and or style(slick, drag radial, tire bulge)? Deep Dish wheel? Wanting the look? Wanting the performance?These are important things to consider and nail down so people can give you advise and options. I know this road all too well and if I could do it over again, better planning would have saved me headaches and money in the long run.
56 Bel Air 2 door HT
JT56 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
