Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Super Stock / Pro Street and Modified Discussion 55-56-57
Super Stock / Pro Street and Modified Discussion 55-56-57 Super Stock / Pro Street and Modified Discussion 55-56-57 Talk engines, race tracks , setup's etc
Old 03-22-2017, 08:43 AM   #51
63chevytoo
63chevytoo's Avatar
Member #3422
Originally Posted by hotrodg726 View Post
In my opinion you should use the biggest bushing in the msd to limit the total distributor advance to around 10 degrees. this will allow for a timing setting of 24 degrees initial and 34 total. should be pretty safe there. however if it runs good as is it might be ok. also depends on weather you have iron heads or aluminum. aluminum heads add a lot of resistance to detonation.
My 383 had MSD dist. 6AL box.
I run 27 initial and 10 mechanical 37 total. I tried 28 and 10 and it made no difference.
I tried locking it out at 38 and it "huffed? back through the carb when it was heat saturated. 10.4:1 compression Dart Pro1 alum. heads mech. roller cam.
His pain, your gain.
63 Chevy II Pro Street
55 Belair 421 700R4
41 Dodge rat truck
63chevytoo is offline   Reply With Quote
Old 03-22-2017, 08:54 AM   #52
63chevytoo
63chevytoo's Avatar
Member #3422
You need to redo the carb settings when you get the timing corrected.
55 Belair 421 700R4
41 Dodge rat truck
Old 03-22-2017, 08:54 AM   #53
HYPURR DBL NKL
HYPURR DBL NKL's Avatar
Member #9112
Originally Posted by Wolfman View Post
Thanks Phil - just curious, what motor do you have? Did it ever run within normal timing range with the mechanical advance enabled?
It's a 10.3:1 383 and it ran fine when it had the old HEI in it, before I switched to the Pro Billet. Initial was like 16 and total was like 36 degrees if I remember correctly.
Phil
Phil's '55 11.22 @ 117 N/A.
HYPURR DBL NKL is offline   Reply With Quote
Old 03-22-2017, 09:37 AM   #54
Wolfman
Wolfman's Avatar
Member #10029
Originally Posted by Churchkey View Post
Need to verify TDC on the balancer.
A positive stop spark plug will work for an assembled engine.
http://www.oreillyauto.com/site/c/de...0869&ppt=C0150
Rotate the engine until it stops then mark the balancer @ the timing tab.
Back the engine up until it stops put another mark on the balancer.
Center distance between the 2 marks is TDC.
Thanks! I never knew of those. Looks like a handy way to find TDC. I'll get one on my way home. I presume you ONLY want to use that while turning by hand.
Joe
Wolfman is offline   Reply With Quote
Old 03-22-2017, 09:45 AM   #55
tator
tator's Avatar
Member #41773
The plug has tabs on it where it will only plug in one direction. I did notice however, that the purple wires did not line up. I thought this was just their design. I better look into that.
You are right the plug only goes in one way. In the picture I am posting I did not change the wire on the one that says wrong. That wiring came from MSD wrong. If that wire is wrong, it will change your timing as much as 15 degrees. It will take you 2 seconds to check the green wire goes to the black and purple. The purple wire goes to the black and orange. MSD told me to switch the wires in the plug, but I had an extra wiring harness. If you doubt me, call MSD direct and they will confirm also. Maybe MSD changed your plug on the box side. Check that too.
tator is online now   Reply With Quote
Old 03-22-2017, 10:03 AM   #56
Wolfman
Wolfman's Avatar
Member #10029
I remember looking at that and thinking it was weird. The purple wires do not line up. If I'm reading your statement correctly, then mine is right. It looks like the wires on the left in your picture.
Joe
Old 03-22-2017, 10:35 AM   #57
Dragsix
Dragsix's Avatar
Member #20785
yes, pull the plugs and hand rotation only. Once you have tdc sorted out, now you can go on to setting up your timing events properly.
Dragsix is online now   Reply With Quote
Old 03-22-2017, 11:00 AM   #58
Wolfman
Wolfman's Avatar
Member #10029
Copy that
Joe
Old 03-22-2017, 01:41 PM   #59
tator
tator's Avatar
Member #41773
I am not trying to hammer home that I am right or wrong, but the problems you are having are almost the same problems I had on my timing and scratched my head for quite a few days to figure out. If for some reason if the plug was backwards on the MSD box end that would make the distributor wires correct but the system would still be backwards. So you would probably have to call MSD and find out which way the wires go on the box end. Not trying to be right or wrong, just something to check.
Old 03-25-2017, 05:06 PM   #60
Wolfman
Wolfman's Avatar
Member #10029
Default Mystery Solved
I called all over town looking for a TDC finder and could not locate one. All special order. So I made one from a 1/2 of a shish-ka-bob stick with a piece of wire taped to it so it would not get lost in the cylinder. Then just used a rag to spin the flywheel.
As it turns out, I hit the TDC at 10 degrees on the damper lined up on the zero on the tab. Exactly the amount that I suspected it was off after firing it up for the first time and setting it by ear.
Now my timing is set from 16 (was 26) at idle, to 34 (was 44) under high RPM, with the 18 degree bushing put back in the distributor.
Thank y'all again for all of your input!
Regards,
Joe
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
