dead cylinders...part time? - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > Engine Building, Hi Performance
Engine Building, Hi Performance Please tell us about your engine builds. What component combos and horsepower output. Let's help each other build better faster engines. Ask or answer questions.
Old 07-03-2019, 06:04 AM   #1
Two-Ten
Member #41847
Default dead cylinders...part time?
Leaving the big car show last weekend and idling up to a stoplight, the engine tone changes from the usual v8 rumble to a smooth weak hum of a 4 cylinder and rpms drop to 500/600. Threw it in neutral and revved it up, problem went away, sounded normal again, regained full power and usual tone until next stoplight. Then it happened again. I couldn't shift into neutral fast enough and it died. After restarting, it was like nothing happened, and I made it back home with no issues, and idled just fine.
Im not sure what was causing this. Revving it up to 'clear' the issue leads me to believe some kind of fuel issue, but seeing as how it went away after restart leads me to an ignition issue?
Engine temp during this scenario was 150-160
Motor is a 327 from 1969 camaro.
Distributor is and HEI type with built in coil. Unsure on brand, it is red.
Carb is 650 edelbrock with manual choke.
700r4 tranny.
I was going to start with new plugs.
Two-Ten is offline   Reply With Quote
Old 07-03-2019, 09:10 AM   #2
alhewitt
alhewitt's Avatar
Member #37639
As mentioned in an earlier post try some non-ethenal gas... Al
alhewitt is offline   Reply With Quote
Old 07-03-2019, 09:31 AM   #3
I would suspect a stuck float valve or trash under the float valve needle.
Old 07-03-2019, 06:37 PM   #4
Jims56
Jims56's Avatar
Member #3765
700r4 tranny.
Don't waste your time on the plugs, 4 plugs aren't going to fail off and on. Sounds like a fuel problem, check the pressure and dirt in the carb.
Retired USAF We own the sky's.
Jims56 is online now   Reply With Quote
Old 07-03-2019, 06:41 PM   #5
TheHotrodHandyman
TheHotrodHandyman's Avatar
Member #8438
Sounds like some dirt in one of your idle circuits to me. Pull both mixture screws out, Give a shot of carb cleaner in there followed by a blast of compressed air. Reinstall the mixture screws, Fire it up and adjust them. See what you have at that point, It is a fairly common issue with the trash they are selling for gas today.
-Bruce
Old 07-03-2019, 07:21 PM   #6
abdiver7777
abdiver7777's Avatar
Member #35808
I had a similarly weird problem but it turned out to be the heat shield/spark plug wire..... after the engine heated up it would occasionally miss...... Turned out the heat shield would expand when hot and get close enough to the heat shield and arc to ground.....
abdiver7777 is online now   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
