Rick L's Alignment Specs - Page 5 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
User Name
Password
Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
Parts on Ebay
Closed Thread
Thread Tools Display Modes
Old 02-23-2017, 12:04 PM   #41
cortcomp
Senior Member
Member #42582
Default
The cornering i'm not as concerned about but i do want straight tracking and not feeling "dicey" when i'm up around 75-85mph. (being a daily driver, i'm not canyon carving with a 4 door but i do drive some highway.) I felt like i read negative camber was noticing the car jumping to the side some at highway speeds when hitting bumps or whatnot? I definitely get that now, and some of the "knife's edge" feel at around 75mph.
Would better directions to them be more in line with:
Caster: Around 3.5 positive total (Drivers 1.5 - Pass 2.0)
Camber: +.5, (.350 each side)
Toe: 1/16
Steering axis inclination: +3.5 to +4.5
The inclination i got off of the linked PDF, do you even give them that or do aligning the caster/camber/toe result in the correct steering axis? I've never asked for specifics there. I don't want to give them un-obtainable numbers or something that is like "Well yeah, if you gave me these that MEANS this" and look like a moron.
cortcomp is offline
Sponsored Links
Advertisement
Old 02-23-2017, 12:58 PM   #42
Rick_L
Trifive Leaders Club
Member #2256
Default
Only toe-in is total. Do not add caster or camber to get a total. I.e. your caster should be 3.5 degrees on passenger side, 3.25 degrees on driver side.
Steering axis inclination is built in to the way the spindle is manufactured. This is the angle of a line drawn through the ball joints when viewing from the front of the car. It is 3.5 degrees on a 55-57 car, inboard at the top. Some alignment machines give you a steering axis inclination on the printout. It is simply the algebraic sum of camber and inclination angle. As an example, with +1 camber, your inclination angle would be (-3.5 + 1) = -2.5 degrees. I personally think this is misleading and confusing. The spindle is not going to change unless it gets bent in a wreck. Camber is a direct measurement that affects the tire patch on the road.
If you are worried about camber making your car "dart around" have them set it at zero.
But more important, positive caster is what makes the car track straight and true, not camber. It also helps in restoring the steering to straight ahead when exiting a turn.
Last thing, you can't get 3.5 degrees positive caster with a totally stock front end. Maybe +1 degree, some cars less. You need aftermarket upper control arms, offset upper control arm shafts, or modifications to the upper control arm mounting brackets to get more.
Rick_L is online now
Old 02-23-2017, 01:32 PM   #43
cortcomp
Senior Member
Member #42582
Default
OK, thanks for that correction! I do have aftermarket uppers and am close to 3.5 now, but i need a re-alignment after a pitman arm swap (new pitman arm is slightly different center, about 1/4 turn off steering wheel now), lowering the car some with the coil cut, and they read my notes wrong last time and did camber negative (i wrote ~.5 camber, meaning around .5...they took it as negative .5)
I could just correct the steering wheel being off, but i don't know how much if any lowering changed anything and i'd like to see how the zero camber feels.
Thanks for the help, i think this would be the way to go now:
Caster: Around +3.5 (Drivers 3.25 - Pass 3.5 to allow for crown in road)
Camber: 0
Toe: 1/16
cortcomp is offline
Old 02-23-2017, 03:17 PM   #44
acardon
acardon's Avatar
Member #1888
Default
Here's a diagram showing steering axis inclination: https://www.trifive.com/garage/57%20C...Manual/3-3.gif
__________________
Don
Sent from my 1981 IBM 5150 PC.
acardon is online now
Old 02-24-2017, 09:09 PM   #45
55 Tony
Member #22177
Default
I have my camber at -.5 and caster +5, equal on both sides since I often drive on 4 lane divided highways were the the left lane slopes the the left and the right lane to the right. With +5 caster the effect on the crown on most any road is hardly noticeable, right or left.
__________________
1955 Bel Air Sport Coupe
55 Tony is online now
Old 03-29-2017, 08:06 PM   #46
quikdime
Senior Member 1 Blue Star
Member #3877
Default Alignment assistance Please
I have a 55 4 door wagon. New custom frame, upper (fully adjustable ) tubular control arms, Tubular lower control arms, 1 inch front sway bar, rack and pinion steering, 4 wheel Alden coil overs, rear 4 link with panhard bar. I am getting aligned tomorrow. What should I tell the man I want? This is a once in a while driver, once in a while canyon car. Advice please. Thanks
quikdime is offline
Old 03-29-2017, 08:16 PM   #47
Rick_L
Member #2256
Default
Use what's already been recommended here.
Sponsored Links
Advertisement
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
