Temperature gauge calibration. - Page 5 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Cooling Systems, Radiators, Fans / A/C
Engine Cooling Systems, Radiators, Fans / Shrouds, water pumps, anything cooling related. Air conditioning etc.
Sponsored By: Cold-Case Aluminum Radiators
Old 05-13-2019, 09:16 AM   #41
charliebrown
Member #37155
Originally Posted by 557B210 View Post
Also, found this post below, recommending the only way to go is with an NOS 1513130 sender.
An NOS sender, so the Lectriclimited Sensor Model 01513130 is not considered a NOS replacement? I've installed the sensor that was in the car when we purchased it and put that thing in a box of parts. Since it reads much higher then the original one.
Do have information on what it's going to take to remove this temperature gauge? Thought I would look to make sure it's grounded properly also.
charliebrown is offline   Reply With Quote
Old 05-13-2019, 09:35 AM   #42
I would test the gauge with a potentiometer first to see if it is bad....Potentiometrs are cheap and will tell you exactly what's going on: https://www.ebay.com/itm/5-x-B500-50...0AAOSwPuRcMQ6X
We need to get some more members to give us some comparative resistance readings of their Lectric Limited 01513130 senders, before we can say yours is a good one....The readings for yours look to be on the low side....Which will cause your gauge to read high.
Old 05-13-2019, 09:59 AM   #43
Tropturq
Tropturq's Avatar
Member #33781
To remove the gauge the instrument cluster must be removed. Here is a link:https://www.trifive.com/forums/showt...luster+removal
Grounding of the temperature gauge is not an issue. The temperature gauge should have two wires connected to it. A pink wire (which provides +12V power to the gauge) when the ignition switch is on, and a green wire (from the temperature sender in the engine compartment). The green wire provides varying resistances to ground depending on coolant temperature. The ground for the gauge is obtained from the sender being screwed into the engine block, (which must be grounded).
I have included the 1956 wiring diagram. The two temperature gauge wires (pink, and green) are shown just right and below center on the diagram.
File Type: jpg 56 chevy Bel Air Wiring Diagram - Copy.jpg (574.2 KB, 3 views)
Tropturq is online now   Reply With Quote
Old 05-13-2019, 01:39 PM   #44
I doubt that a bad ground is the problem in this case...Think about it...A bad or weak ground will cause the gauge to to read lower, not higher.
When you turn on the ignition and take wire off of sender, the temperature gauge should go to empty....A bad or weak ground (open condition) will cause lower readings than normal....Shorting the sender wire causes the gauge to indicate past full.
Old 05-13-2019, 02:48 PM   #45
mr55/56
Member #25615
I understand the issue here, but having owned my 56 most of my life I do not have this problem. Do I have the correct sender no, mine is a used one from an early 70s Chevy truck. Does it read correct, yes I believe it does, how do I know, the needle tracks with the mechanical SW hanging below dash.
mr55/56 is offline   Reply With Quote
Similar Threads
new fuel sender calibration tjsdelivery Electrical Questions and Answers 3 08-11-2012 11:01 AM
Speedometer Calibration acardon Stock Chevy Discussion 55-56-57 8 06-19-2012 10:51 AM
Fuel Sender/Guage calibration Classic57 Fuel Systems, Fuel Injection, Carburation, Supercharging 4 09-10-2010 03:37 PM
BelEra Classic Instruments real time calibration joeelutz Electrical Questions and Answers 0 08-01-2010 07:01 PM
Need help on 1957 speedometer calibration NEW TO 57 New Member Introductions 6 11-25-2008 03:49 PM
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
