Holley Sniper - Ignition Wire - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Electrical Questions and Answers
Electrical Questions and Answers This is the place to ask all your question about electrical problems and instalation issues.
Old 03-11-2020, 09:05 PM   #1
68Dart
68Dart's Avatar
Member #35442
Default Holley Sniper - Ignition Wire
Wiring up the Holley Sniper on the ‘55 and need to find a “clean” switched 12v power source that has power while cranking & run positions. Instructions say there should be no other accessories hooked to this wire.
What’s the best way to handle this? It’s a small block, hei with alternator.
Have the hyper spark going in once I get things up and running.
Thanks,
Jay
55 Bel Air Two Door Sedan
350, 4 speed, 3:55's
68Dart is online now   Reply With Quote
Old 03-11-2020, 09:49 PM   #2
Use the IGN1 terminal on the ignition switch and jumper the IGN2 terminal to it. That will get you power in both start and run positions on the switch. Put anything else on the ACC terminal - that's what is usually done and should be - even without the Sniper.
Old 03-11-2020, 09:57 PM   #3
68Dart
68Dart's Avatar
Member #35442
I’ll check that but I feel like I may have wired the HEI that way. It specifically says to not hook to the ignition coil so I’m a little unsure where to go.
Old 03-11-2020, 10:06 PM   #4
Crowbarman55
Crowbarman55's Avatar
Member #6978
Wait for the HyperSpark Distributor, coil and box. It's hard to not get excited and want to get it running, but it's worth waiting. I know you didn't ask, but be SURE to run all the power wires to the battery ONLY. And make sure your grounds are perfect. My friend had bad things happen with the HEI with just the sniper.
Good luck.
Todd
Crowbarman55 is online now   Reply With Quote
Old 03-11-2020, 10:16 PM   #5
68Dart
68Dart's Avatar
Member #35442
I have the Hyperspark package but even the Sniper instructions recommend firing up on the existing ignition to limit the number issues with getting the unit installed and fired up. I tend to like that plan myself as I hate chasing problems from so many changes at one time.
Old 03-11-2020, 10:33 PM   #6
Crowbarman55
Member #6978
Then I would fire it up per the instructions with your ignition. But what if someone was starting with a fresh engine and didn't have existing ignition? I don't expect you to answer that question. I am just thinking out loud.
Keep us posted .
Todd
Old 03-15-2020, 09:07 PM   #7
rayharris
rayharris has made a donation to the forum!
rayharris's Avatar
Member #16151
Check the voltage while cranking. It should read 10.6 volts at least.
Ray
"Dreading it, is the worst part of the job."
rayharris is offline   Reply With Quote
Old 03-15-2020, 09:41 PM   #8
Seems like a relay off the battery would be the best way to get clean power to the Sniper. Use ign1 & 2 to energize the relay.
Old 03-16-2020, 08:19 AM   #9
68Dart
68Dart's Avatar
Member #35442
Thanks Acardon. That's what I was thinking. The Holley diagram shows all three "ignition" wires tied together so that's what I did to get it running yesterday. I can't imagine I'd need three separate relay's as there are three wires (Sniper, Spark Box & Distributor).
What's your thought there?
Thanks,
Jay.
Old 03-16-2020, 12:48 PM   #10
Thanks,
Jay.
I would run the Sniper off the relay and the ignition directly off the switch. Their intent is to separate the Sniper from any electrical noise source from the ignition.
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
