Russell fuel starlight hose - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > Fuel Systems, Fuel Injection, Carburation, Supercharging
Fuel Systems, Fuel Injection, Carburation, Supercharging Fuel Systems, Fuel Injection, Carburation, Supercharging, Questions and answers.
Old 03-11-2020, 09:11 AM   #1
victor
Member #9341
Default Russell fuel starlight hose
has anyone used Russell hose for fuel line . was thinking of using from tank to carb instead of hard line .I am not using the stock tank .I bought a new 20-25 gal tank from CPP for my 55. I do not have any experience in bending line at all thanks for the help and time victor
victor is offline   Reply With Quote
Old 03-11-2020, 09:21 AM   #2
68Dart
68Dart's Avatar
Member #35442
If stainless braided, I'd recommend the corresponding tool from Koul Tools. Assembling them sucks. I'm ordering the -6an tool myself looks well worth the $30.
55 Bel Air Two Door Sedan
350, 4 speed, 3:55's
68Dart is offline   Reply With Quote
Old 03-11-2020, 11:22 AM   #3
HotRod Junkie
HotRod Junkie's Avatar
Member #33509
Hey Victor ,
I use the Russell "Pro Classic" black nylon braided line
In fact , I even run this hose on my 57 - 150 that's running E85
Been using it for many years .. ZERO issues
Hope this helps
HotRod Junkie is offline   Reply With Quote
Old 03-11-2020, 12:48 PM   #4
68Dart
68Dart's Avatar
Member #35442
Originally Posted by HotRod Junkie View Post
Hey Victor ,
Hope this helps
I'm using the black braided on my current fuel injection install only because it's a million times easier to thread on the "an" fittings. Problem is I like the abrasion resistance that the stainless had. Only issue is anything the stainless rubs against, it scratches, so you have to make sure it's secured well all the up to the motor.
Since finding out about the Koul Tool I mentioned, I plan to order and swap out my lines at some point for stainless braided again.
Old 03-11-2020, 04:06 PM   #5
Foolish and expensive to run braided hose front to back. Run flex from tank to hard line on frame, hardline front to back on frame, and flex from front of hardline on frame to engine.
Not to mention all rubber based braided hoses are subject to rod from the inside like regular rubber hose. so do you want to replace 4 foot of hose or 20 foot of hose.
Now if you choose a Teflon lined braided hose then it is good for longer than you will live and the cost of the hose and fittings goes up about 40%
hotrodg726 is offline   Reply With Quote
Old 03-11-2020, 08:20 PM   #6
68Dart
68Dart's Avatar
Member #35442
Good idea. I like that.
Old 03-13-2020, 07:56 AM   #7
victor
Member #9341
Thanks guys I have zero experience at bending hard line and flare the ends or have the tools for it that is why I was thinking of Russell fuel hose and so I could use AN fittings for tank and carb as well
Old 03-13-2020, 08:45 AM   #8
68Dart
68Dart's Avatar
Member #35442
Unfortunately, none of the fairly inexpensive flaring kits reliable flare 3/8" fuel line. I've had kits from both Matco & OTC and neither would flare it more than once / twice before the clamp starts slipping. You'll need a hydraulic flaring kit. Thus same reason I went with braided. Although a good flaring tool would be a good investment overall.
Sounds like the PTFE hose is the way to go. Just a little more money upfront.
Old 03-13-2020, 04:23 PM   #9
Old Buzzard
Old Buzzard's Avatar
Member #3388
Send a message via AIM to Old Buzzard
"Sounds like the PTFE hose is the way to go. Just a little more money upfront."
As a caution: The PTFE hose is relatively stiff, and cannot be put into a tight radius. Doing so, will kink the liner.
It's no fun to assemble, either. The outer shell has to be stripped back, the braid flared out, so the "olive" can be pushed over the liner. Then, getting the braid into the end of the fitting can be a hassle.
Injector inspector.
55 210 sedan, rust bucket. The last hoorah!
Hotrodding and dragracing since 1955.
USAF, 67th Recon Tech. Yokota AFB, Japan.
6594th Test sqdn, Westover, AFB, MA. The guys that brought you the Cuban missile pics. 1960-64.
Old Buzzard is online now   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
