4 blade fan - Page 4 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Stock Chevy Discussion 55-56-57
Stock Chevy Discussion 55-56-57 Stock Chevy Discussion, 55-56-57 Ask your Questions or help others with answers. Or any general Talk about stock Chevy's
Old 03-13-2020, 03:10 PM   #31
Carmine
Member #6592
Originally Posted by TheHotrodHandyman View Post
It is a 265 and all stock internally. It runs at 165-170 all day long even with the A/C on it only goes up a few degrees. It will creep up to 185-190 in traffic but never gets to the point of any concern. A shroud can always be added if needed.
Very nice and good to know. Thanks, Carmine
Carmine is online now   Reply With Quote
Old 03-29-2020, 10:14 AM   #32
Waited50years
Member #52144
I tried the Derale 17317 fan on my '56. Stock 265 with a 4 row radiator and stock 2 groove pulley. I could only get about 3/8" clearance between the fan and the radiator. Core support is moved as far towards the grille as it can be to gain extra space. If the fan tips were not bent as much this fan probably would have worked. I'm hoping to find a 5 blade OEM fan and may install an electric pusher also.
Leonard
Waited50years is offline   Reply With Quote
Old 03-29-2020, 10:21 AM   #33
TheHotrodHandyman
TheHotrodHandyman's Avatar
Member #8438
Leonard
The issue you are running into is your 4 row radiator is thicker than the stock radiator. If you had a stock or aluminum 2 row core you would have plenty of room. The number of grooves in your pulleys have nothing to do with your problem.
-Bruce
Old 03-29-2020, 10:25 AM   #34
Waited50years
Member #52144
Thanks Bruce.
Old 03-29-2020, 10:37 AM   #35
Waited50years
Member #52144
Another question:
Does anyone have any fan recommendations when you have a 4 row radiator, radiator in V8 position, stock 265?
Leonard
Old 03-29-2020, 11:02 AM   #36
TheHotrodHandyman
Member #8438
You probably don't want to hear it but my honest recommendation is get rid of the 4 row radiator. I have a friend that put a 4 row desert cooler in his 55 to replace the 60 year old original radiator and with no other changes the car ran hotter than it did with the original well used & abused radiator. He went to a 2 row aluminum radiator again with no other changes and the temps were normal 180-185. More rows of smaller tubes will not run cooler than less rows of larger tubes, It is just the way it is.
-Bruce
Old 03-29-2020, 11:12 AM   #37
Another question:
Leonard
Agree with Bruce....The only way out I can see is an electric pusher fan (not recommended)...Another option might be a Derale or Spal super thin puller fan....You will have to call one of them for a recommendation.
* See my painfully slow and overly detailed build thread here: https://www.trifive.com/forums/showthread.php?t=79427
* I have a vast data base of TriFive restoration & upgrade articles for our members' use...Send me a PM with your EMAIL ADDRESS and subject matter...See this link:
* Contact me by PM to purchase your PHR's Project X and TriFive Gasser Building CD's
_________________david aka POPS & sherry
Old 03-29-2020, 11:51 AM   #38
Waited50years
Member #52144
Since I'm learning, why do you not recommend a pusher fan? I see a lot of them on the tri-fives. Of course a lot of them are with LS conversions and no mechanical fan.
Leonard
Old 03-29-2020, 01:14 PM   #39
A pusher fan blocks air flow through the radiator.
Old 03-29-2020, 01:27 PM   #40
TheHotrodHandyman
Member #8438
Leonard
The 2 reasons I wouldn't consider a pusher fan. The fan motor blocks part of your core from doing any real cooling and if you need a shroud they don't work with a pusher.
-Bruce
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
