Transmission Linkage Problem w/Side Trans mounts? - Page 2 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Old 03-12-2020, 10:40 AM   #11
X2 what Bruce said...My other 55 with a 350 V8 and 200R was originally configured with just front motor mounts and a transmission tailshaft mount by the previous owner....I did not know that, when I first got the car...I experienced first hand how the throttle can stick with that tripod set-up and you get on it.
* See my painfully slow and overly detailed build thread here: https://www.trifive.com/forums/showthread.php?t=79427
* I have a vast data base of TriFive restoration & upgrade articles for our members' use...Send me a PM with your EMAIL ADDRESS and subject matter...See this link:
* Contact me by PM to purchase your PHR's Project X and TriFive Gasser Building CD's
_________________david aka POPS & sherry
Old 03-12-2020, 03:29 PM   #12
Mel56
Mel56 has made a donation to the forum!
Mel56's Avatar
Member #2020
Oh, no question you and Bruce are correct. This car had a dead battery and we helped restart it. Once it was running, we saw how it 'jumped'. This was after the owners had a TH350 installed to their 283. So, side motor mounts were ordered but, soon discovered that an original 283 from 1957 did not have access for side motor mounts. Which got us to this point.
Getting closer.
Trying to get this car ready for the Western Invasion in May.
Mel
Mel56 is offline   Reply With Quote
Old 03-12-2020, 05:18 PM   #13
Mel
Old 03-12-2020, 08:38 PM   #14
OldybutGoody
OldybutGoody's Avatar
Member #43028
I donít have the trans frame side mounts, but if you have line of sight from the column shift arm to the the trans shift lever, this Lokar trans arm linkage is a good solution. Gives you a lot if adjustment flexibility. Easy installation, works great IMG_1401.pngwith a 700r4, for me.
Sent from my iPhone using Tapatalk
My '55 Bel Air Sport Coupe
OldybutGoody is online now   Reply With Quote
Old 03-12-2020, 08:51 PM   #15
OldybutGoody
Member #43028
This Lokar column cable shift might be your best solution. It would allow you to go around the bell housing side IMG_1402.pngmount.
Old 03-12-2020, 11:09 PM   #16
55Laurentian
55Laurentian's Avatar
Member #45258
Here is some of the pics I took when I installed the TH350 in my old 57 with stock 283 the other year ago. I remember having to grind around the mount to the bell housing just to fit past the casting.
Michael Chudyk
Instagram @drivinghistory Follow if you dare!
1955 Pontiac Laurentian (MY FIRST CAR - Canadian Poncho with Chevy guts)
265 PowerPack 4bbl, solid lifters with Muncie M21 4spd
https://www.trifive.com/forums/showthread.php?t=179480
1957 Chevrolet 210 2DR Sedan Del-Ray - Sierra Gold/Adobe Beige
350, 700R, Current project
https://www.trifive.com/forums/showt...46#post2362046
55Laurentian is online now   Reply With Quote
Old 03-12-2020, 11:18 PM   #17
55Laurentian
Member #45258
Here's a couple from the starter side. I forgot what I did about the linkage, but I know it was a bit tricky at first. All Danchuk stuff I used too.
Michael Chudyk
Old 03-13-2020, 03:40 PM   #18
Mel56
Mel56's Avatar
Member #2020
Originally Posted by OldybutGoody View Post
This Lokar column cable shift might be your best solution. It would allow you to go around the bell housing side Attachment 227852mount.
This cable linkage might be the answer. Thanks!
Mel
Old 03-13-2020, 03:42 PM   #19
Mel56
Mel56's Avatar
Member #2020
Thanks for the pics! My friend bought everything from Danchuk's. The trans mount and trans linkage. But, with this setup there's no way Danchuk's linkage will work without heavily modifying it.
Mel
Old 03-13-2020, 04:29 PM   #20
55Laurentian
Member #45258
You made sure the arm on the linkage to transmission is pointing down? And it should barely clear the bottom of the mounts. I even removed the old bellcrank attachments from the old linkage on the frame.
Michael Chudyk
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
