Header Recommendation?
14K views 22 replies 14 participants last post by  mickeywestsr
#1 ·
What headers would you guys recommend? The more affordable, the better:p3:
'57 sbc, motor 3/4" forward
The car sits at 5", so clearance is an issue.
Long tube, or shorty's?
I'd prefer long tubes.
Any advise will be greatly appreciated.
#3 ·
Williams Classic Chassis long tube headers will be the most expensive but will fit up in frame rail $989
hooker 2458-4 might be most cost efficient $450
Sanderson C56 $575
Doug's D353 $630 - 650
All prices are for coated headers
I bought Headman 68128 $450 but mine hang low below the frame while others hang about halfway below frame rails.
For better clearance most go with 3/4 headers like Patriot or Doug's. Plenty of discussions try doing a search above.
:anim_25:
#14 ·
I have Hookers on the 350 in the Nomad I just purchased. The engine has TBI heads which I plan to remove for something hotter, and a good midrange cam. I plan to keep the Hookers as they seem to fit well, but I do plan on replacing the 24" glasspacks.
I'd replace them with coated Sanderson's if they needed to be replaced.
Bob
#15 ·
I have 3/4 patriots on my car. A real pain to install. Had to modify side engine mounts, purchase a mini starter and still had to heat and beat the pass side for clearance at the collector. Also requires shorty plugs in a couple of spots. The good thing is they do not loosen and do not leak. Cheap headers IMO have a tendency to loosen and leak.
I run a 406 CID SBC
