THM 350 starts in 3rd gear - Page 2 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Old 05-22-2020, 08:05 AM   #11
56ls408
56ls408's Avatar
Member #50214
i spoke with my friend who is one of the best trans builders in the indy area & unlike me is still building transmissions every day his thoughts are also the governor but doesn't make sense with what was done he said you might want to drive the pin out of the gov gear & take it apart said that there is a small opening in the valve that might have something stuck in it & it would cause third gear starts good luck don't know if it's any help or not
56ls408 is offline   Reply With Quote
Old 05-22-2020, 10:54 AM   #12
Crowbarman55
Crowbarman55's Avatar
Member #6978
Are you sure it's just not super soft shifts? My 350 shifts soft and can't feel them. If you don't have a tachometer hook one up and see if it shifts.
Todd
Crowbarman55 is offline   Reply With Quote
Old 05-22-2020, 11:02 AM   #13
techman441
techman441's Avatar
Member #24578
The only 3rd gear start I've seen was caused by melted direct and forward clutches..
techman441 is offline   Reply With Quote
Old 05-22-2020, 01:10 PM   #14
56ls408
56ls408's Avatar
Member #50214
normally with the direct & forward clutches burnt to the point they kind of weld themself together if you pulled it into manual low it will try to bind up & it shouldn't shift to second & third manually it's a unusual situation with what was done to it especially plus he said it was shifting fine before the converter & seal change. In manual low you bring the low reverse clutch on where in drive that clutch doesn't apply
Old 05-22-2020, 07:36 PM   #15
techman441
techman441's Avatar
Member #24578
If it's welded it's applied..
Old 05-22-2020, 07:52 PM   #16
56ls408
56ls408's Avatar
Member #50214
pull the pan if it's burnt up that bad it will be very obvious
Old 05-22-2020, 08:25 PM   #17
If both forward and direct clutches were "welded", it wouldn't have manual low or manual second. The transmission would lock up in manual low, as suggested. Also there would be no neutral and it would lock up in reverse too.
If the problem isn't in the governor, it's in the valve body. Probably a stuck shift valve.
Old 05-22-2020, 09:07 PM   #18
56ls408
56ls408's Avatar
Member #50214
the power flow is that the low reverse clutches only apply in reverse & manual low in drive range the low sprag is applied & the low reverse clutch isn't I don't remember all the power flow in all ranges any more i used to as that's what i did for a living back in the early seventies only do one every now & then for a friend If i was the OP i'd pull the pan see what things look like if it's not bad think i'd change the governor as you said about have to be that or a stuck valve
Old 05-22-2020, 09:56 PM   #19
In the "drive" or D position, first gear is accomplished by the forward clutch being applied as well as the first gear sprag. Second gear is accomplished by the second gear clutches applied as well as the second gear sprag, the first gear sprag overruns in second gear. Third gear is accomplished by the direct clutch being applied, and the second gear sprag overruns. The forward clutch is applied in all forward gears.
In manual low, the low/reverse clutch is applied, as well as the forward clutch.
In manual second the second gear band is applied as well as the forward clutch.
If both sprags were broken, the car wouldn't move. This would be very rare to have both sprags broken. I've had the second gear sprag break, this results in starting out in first gear and eventually shifting to third gear. Very rare for the first gear sprag to break, but I guess it could happen. This would result in the car not moving.
In reverse, the low/reverse clutch as well as the direct clutch is applied.
Old 05-22-2020, 10:21 PM   #20
56ls408
56ls408's Avatar
Member #50214
sounds right but i couldn't t remember it all & didn't want to be inaccurate fortunately they still have manuals on at least the old stuff GM went to online only about the time I left the dealership in 2008 they used to send you a ton of paper manuals they also did away with the technical training centers a few years before that changing over to almost all distance learning at least when ever the equipment worked properly
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
