Fuel sending unit with return line - Page 2 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > This is a list of our Official Sponsors , Quality 55-56-57 parts Click Here > Ecklers Special Area of Trifive.com
User Name
Password
Ecklers Special Area of Trifive.com This his special area of the Forum belongs to Ecklers, Members can ask questions and get answers about Ecklers, parts and policies, and get free Tech support about Ecklers Products only. Post about any other company’s products or services will be deleted if posted in this forum
Parts on Ebay
Reply
Thread Tools Display Modes
Old 08-23-2017, 10:57 PM   #11
abdiver7777
Senior Member 2 Gold Stars
abdiver7777's Avatar
Member #35808
Default
Quote:
Originally Posted by 55Moredoor View Post
Ouch! 2K is a bit spendy for this cowboy!
I thought maybe the pump, regulator and fittings came in a kit that was a bit cheaper than buying separately. I'll be feeding a 6L LS engine and will be using the same pump setup. Thanks for the post though.
The link I posted lists it at $1250.00......
That's it... you don't need anything else! Where did you see $2k?
A new Holley 4bbl will cost between $500.00 - $600.00....
abdiver7777 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-23-2017, 11:13 PM   #12
55Moredoor
Senior Member 1 Silver Star
55Moredoor's Avatar
Member #41731
Default
My bad! I was sure I saw $2k, but regardless $1250 US is still $1568 Canadian and still too spendy for me.
__________________
Nothing is ever as hard or as easy as it first appears to be!
55Moredoor is offline   Reply With Quote
Old 08-23-2017, 11:34 PM   #13
wildfifty6
wildfifty6's Avatar
Member #7435
Default
Quote:
Originally Posted by Rick_L View Post
A cheap easy way of adding a return line is to buy the Moroso kit that puts it in your filler tube. No welding needed, just a saw and a screwdriver.
Hmm That would have been good to know earlier... LOL
Here is the link
https://www.summitracing.com/parts/MOR-65385/
wildfifty6 is offline   Reply With Quote
Old 08-23-2017, 11:40 PM   #14
wildfifty6
wildfifty6's Avatar
Member #7435
Default
Quote:
Originally Posted by abdiver7777 View Post
Would you mind posting pictures of the pump mounting and installation?
I have my Sniper kit ready and just finished replacing the dual-plane manifold with a single-plane on my ZZ4....
Note: A noticeable difference in low end torq loss with the single plane manifold..... I don't really care since it is my driver and not a race car....
Curious.... How low were you able turn down the idle?I heard that is a problem.
Thanks in advance!
The idle did not seem to be a problem... I just followed the instructions..
As far as mounting the pump ... I already had two bolts through the trunk pan from the old systems electric pump.. I mounted the pump on a short piece of aluminum angle and mounted the angle with the old bolts through the floor.. It is a little closer to the exhaust than I would like but hasn't seemed to be a problem.
Old 08-24-2017, 12:30 PM   #15
abdiver7777
Member #35808
Default
I'm mainly curious about the elevation of the pump and its ability to prime itself. It seems to me that too low makes it vulnerable to getting torn off from road debris and too high might impair its ability to prime itself.... Should the bottom of the pump be at least as low as the bottom of the fuel tank? The Ecklers sending unit draws from the tank bottom but the fuel has to climb over the sending unit then down into the pump suction....???
Thanks!
Old 08-24-2017, 07:36 PM   #16
55Moredoor
55Moredoor's Avatar
Member #41731
Default
Thanks!
I was wondering about the same thing, pump elevation.
Just recently while taking a motor out of a truck, we disconnected the fuel line and anytime the end of the gas line was below the level of the gas in the tank, gas would syphon out - even though the line was routed out the top of the tank. I'm hoping that mounting the pump slightly lower than the bottom of the tank will have the same effect and the pump will stay primed.
If the pump is too exposed to road debris, I'm thinking I could then fabricate some kind of mesh protector that would block debris and still let air get to the pump.
__________________
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
