Bam bam's 57 - Page 3 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Welcome to Trifive > Project Update Section, Post your Project updates here
User Name
Password
Project Update Section, Post your Project updates here This section is for Project Updates only, So post any updates of your trifive projects. >Do not post tech questions in this area of the forum = Remember only projects updates should be posted here.
Parts on Ebay
Reply
Thread Tools Display Modes
Old 11-02-2019, 11:02 PM   #21
FUZZY
FUZZY's Avatar
Member #5938
Default
Now on to Bam bam's car. I got to tinkering on it this week an did some metal fabbing n patch work where needed. Been going easy as my back only holds up for so long n i need a break. The pics aren't upside down the car is.
Sent from my SM-G955U using Tapatalk
FUZZY is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-02-2019, 11:15 PM   #22
FUZZY
FUZZY's Avatar
Member #5938
Default
Today i hit it much harder n finally had to quit after 12 hours steady. Fit the decklid, adjusted the rear body n lid to fit correctly, aligned the passenger door, straightend n rewelded the pass qrt patch, stripped the pass side to see what was under the primers. The qtr n roof were prepped well n had a fearherfill type surfacer on it that was rather thick. The door had minimal primer n i'm glad i stripped it. Found quite a bit of rust pitting n not so good mud work. Nothing that couldnt be fixed with a little spot blasting, n hammer n dollying. Still have a bit left to board out (hopefully the last skim coat), but it's coming along. Also blocked out half the roof.
Old 11-02-2019, 11:19 PM   #23
FUZZY
FUZZY's Avatar
Member #5938
Default
The little procupine needles were to do some strss relief where the qtr patches were previously welded n warped. A little outward pressure here a n a beating on the drum there and after a little while it was straight with no more tin canning effect. Worked like a charm.
Old 11-03-2019, 11:29 AM   #24
bam bam
Trifive Leaders Club
bam bam has made a donation to the forum!
bam bam's Avatar
Member #12584
Default
Thanks for all your hard work .
Dean
bam bam is online now   Reply With Quote
Old 11-03-2019, 11:40 AM   #25
Dragsix
Dragsix has made a donation to the forum!
Dragsix's Avatar
Member #20785
Default
Man o man, I am nothing but a backyard hacker pure and simple, so I am always in awe of those that can do the kind of work you do Fuzzy. Deanís car looks like itís coming along great!
__________________
ATFA Charter Member #23
Dragsix is online now   Reply With Quote
Old 11-03-2019, 07:08 PM   #26
FUZZY
FUZZY's Avatar
Member #5938
Default
Hope everyone else reset their clocks last night. I didn't. So that means i've been in the shop an hour longer today. My bad.
Finished boarding the pass side and roof. Had to fix a few spots on the roof. Small dents, old pits, n ripples from blasting. Also prepped the dash n firewall.
Primed up the roof in black as long as i had the body hanging sideways. Layed down 6 coats to make sure there was enough to block out any remaining ripples that i may have missed with the lighter color.
Then flipped it back right side up n primed the pass side, dash n firewall in redish primer. Layed down 4 on them. They can set till the other side n trunk are done.
The door gaps to the qtr n rocker look good.
I'll work on the driver side tomorrow till the other 57 gets here for a suspension rebuild.
Old 11-03-2019, 07:10 PM   #27
FUZZY
FUZZY's Avatar
Member #5938
Default
I've got seam sealer n a few other materials comin in tomorrow. Then all the seams can be sealed up properly.
Old 11-03-2019, 07:25 PM   #28
Big Bob
Big Bob's Avatar
Member #19595
Smile
Hey,its coming along pretty nicely.Keep up the good work,press on and keep those updates coming.
Big Bob is offline   Reply With Quote
Old 11-03-2019, 07:46 PM   #29
bam bam
bam bam's Avatar
Member #12584
Default
real real nice thanks fuzzy
Old 11-08-2019, 08:29 PM   #30
FUZZY
FUZZY's Avatar
Member #5938
Default
The suspension on the other 57 took a little longer than expected. Once into it i found a bent control arm. I dug out a pair i had in the shed n put all the new bushings n ball joints in them before installing.
Been on Bam bam's car for the past 2 days again getting the metalwork done on the driver side n finishing it off. Just finished applying 3 coats of primer.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
