Not sure any other makes will fit exactly, but you can pick up good used ones for not a lot of money or even a custom one made specific to your application.
It's not just diameter, it's what u-joint is used at the ends.
Answer is there are many vehicles that use the same or similar diameter and the same u-joints. But few will have the same length too.
Be aware that a new driveshaft can be manufactured using the u-joints you need and the length you need.
Also be aware that it's not all that difficult or expensive to shorten an existing driveshaft if it's too long. But you can't successfully lengthen one.
If you need a stock length driveshaft, there are still plenty of used ones out there.
Used tri five chevy drive shafts are scarce as hen's teeth around here, Ecklers is out of stock. Hope to find one in Bowling Green next month. The ends on mine are so banged up the U joint caps can't be removed and can't be reused. Thanks
I used an early 80s Ford Crown junk in my 55, had to be shortened, but it used same 1310 Spicer joints. Cost me $90 to shorten & balance & $24 for two Spicer u -joints.
Hi everyone,
I was wondering what the original driveshaft lengths are for a 1957 Nomad & a 1957 Truck. Center of yoke to center of yoke. I have a few driveshafts that I dug out of a barn where my Dad used to live. I don't know what they were out of, but he was into tri-five cars. From What I measure they are 53", 60", 62" a few 2-piece shafts that measure 65" total length.
Thank you everyone. I will try to get more accurate measurements when I get to where I have them stored. Also I will get some pictures, especially of the two piece shaft to see if anyone can tell me what that would be out of.
Thanks again.
Related Threads
Chevy Tri Five Forum
2.5M posts
62.4K members
Since 2005
