Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Metal Fabrication & Repair Questions > Paint & Bodywork Questions and Answers
Paint & Bodywork Questions and Answers Paint & Bodywork Questions and Answers
Old 03-11-2017, 08:57 PM   #21
rbrewer
rbrewer has made a donation to the forum!
Member #10996
Originally Posted by Rick_L View Post
Not knowing what yours look like, most of the rust I've seen on the backside of stainless trim is a stain from the clip that fastens the trim to the body. Original clips are usually rusty somewhere even if otherwise in good shape. Others are about to fail.
I wouldn't worry about it too much if it won't show, as it's just a stain and not a flaw. And you'll install new clips if they are rusty.
Thanks Rick!
"correct" I've got a complete set of new clips
Best wish's
Bob B
G Burg MD
rbrewer is offline   Reply With Quote
Old 03-12-2017, 11:28 AM   #22
TrevO
TrevO's Avatar
Member #21559
Are you guys putting anything, in terms of a gasket, between the stainless trim and the body? If so, what are you using?
TrevO is offline   Reply With Quote
Old 03-12-2017, 11:57 AM   #23
55wagoncrazy
Stainless Trim Restoration
55wagoncrazy has made a donation to the forum!
55wagoncrazy's Avatar
Member #22828
Believe it or not, I have been using hot water and SOS pads to clean the back side of ALL the stainless trim I restore. It cleans well, and will brighten the trim. I do this so I can find the dents from the back side. If I can't see it how am I going to know where to straighten.
Scotch bright pads will also work, but they leave fine scratches and this hinders being able to see the dent from the back side. But it will remove the stain from the clips.
37 Years of Professional Restoration of anything on a 55-57 Chevy
Michael Domoracki (Mikey)
The Stainless Shoppe Restorations
N8143 State HWY 55
Seymour WI 54165
920 833 0290 Sunday -Friday 8AM till Sundown. Closed Sabbath until Sundown Saturday night
55wagoncrazy is offline   Reply With Quote
Old 03-12-2017, 12:00 PM   #24
55wagoncrazy
Member #22828
I don't recommend this. The trim was designed to fit on the surface. If you put something between it, it will lift the trim. Around windows and such this will become a problem.
N8143 State HWY 55
Seymour WI 54165
Old 03-12-2017, 12:05 PM   #25
mudflat
mudflat's Avatar
Member #7985
Is there any good "How to remove trim from a 57 2door hardtop"?
mudflat is offline   Reply With Quote
Old 03-12-2017, 12:11 PM   #26
55wagoncrazy
Member #22828
Here are photos of the finished trim fielddad (Jerry Hooper) sent me. These were shipped back to him on 3/10/17
The fine polishing marks seen in the photos are the result of the flash of the camera. They are not as visible in natural light
N8143 State HWY 55
Seymour WI 54165
Old 03-12-2017, 01:04 PM   #27
3831957
3831957 has made a donation to the forum!
3831957's Avatar
Member #34694
Looks better than new !!! later Jason
3831957 is offline   Reply With Quote
Old 03-12-2017, 06:00 PM   #28
55wagoncrazy
Member #22828
What ever you do PLEASE DON'T PRY IT OFF.
All of the side trim has stud and nut or screws that hold it on the ends. Most of the fender trim has stud and nut clips all the way front to back.
The lower windshield has clips with studs and nuts. The nuts need to be removed from inside. The ends have screws on them that are in the jamb of the windshield post.
The upper windshield trim is placed into a slot in the rubber gasket BEFORE the windshield is installed in the car. The windshield and gasket must be pulled to release the trim.
All the belt line, vent window trim has screws holding it on. The windows and vent inner frame MUST be removed BEFORE you can access the screws.
The rear quarter stainless has screws holding it on, the quarter window MUST be removed to access the screws.
The flippers and the upper window guide for the quarter window has screw holding it on. Locate and remove them.
The Rear "B" post sail panel has a tab on the back that is hidden by the rear window trim. It has a screw holding it in.
To remove the rear window trim: remove the upper 90 degree corners first. They have a stud that goes inside the car. Remove the nut and push the stud out. The 3 main pcs of stainless have claw hook clips that hold it in place. They make a special tool to release the clips. Sometimes you can get it off without the tool. Most of the time if you pry on it you will damage it. I have fixed 100's of these with problems caused from poor removal. Many have to be replaced because they were ripped off and the distortion is not repairable.
N8143 State HWY 55
Seymour WI 54165
Old 03-12-2017, 09:25 PM   #29
fielddad
Member #32222
Looks good, can't wait to get them on the car.
fielddad is offline   Reply With Quote
Old 03-20-2017, 06:51 PM   #30
57larry
57larry's Avatar
Member #2475
where can I get some trim clips for the stainless that goes above & below my door windows on a 4 door wagon. only need a few.
anybody on here polish aluminum trim? thanks, Larry
57larry is offline   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
