Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Trifive Gassers
Trifive Gassers Trifive Gassers Discussion, 55-56-57 Ask your Questions or help others with answers. Or any general Talk about Trifive Gassers, How to Build , Parts Etc
Old 06-18-2017, 03:59 PM   #11
tator
tator's Avatar
Member #41773
This is some pictures of a 1937 chev that I recently finished for a friend of mine that did the paint and body work on my 55 chevy, "chevy light". On all of these cars that I build, I buy the tires and wheels first because you have to buy them anyway. I set the car at the ride height I want, put the tires in the wheel wells, move them in and out and front to back until I get the car to look exactly the way I want it. I measure between the two wheels on the inside. That is your hub to hub measurement for your axel. Speedway will make the axel any width you want it. This is real close, depending on how heavy your motor is, but ride height should put the bottom of the frame rail about 8 1/2 inches from the top of the axel. In my opinion a tire and wheel that is even 1/2 inch too far in or out spoils the look of the whole car.
tator is online now   Reply With Quote
Old 06-18-2017, 04:59 PM   #12
nad427
nad427 has made a donation to the forum!
nad427's Avatar
Member #25732
Originally Posted by easyways View Post
Daniel ,
I have to mention that I struggled with the long stud fat tires and how to fight them on and off the car , jack it a mile in the air and take loose a spring shackle !!!! Finally I gave into reality and simply opened the wheel opening . It looks great " Butch " told me once it does and suddenly the problem just went away !!! Another problem solved with elegant simplicity : )
Well, on mine I have to disconnect the coilovers, drop it down, then let every speck of air out of the tire (or tires) and fight like a Gorilla to get them off.
As much as I like 55's with radius wells, I'm not a big fan of opened up wells on a 56. The only one I've seen that I've liked belongs to a member here. I haven't seen him post for quite a while though.
nad427 is offline   Reply With Quote
Old 06-18-2017, 06:43 PM   #13
nad427
nad427's Avatar
Member #25732
Daniel !! Are you saying mine doesn't look great ??????
That combined with ease of ingress egress how could you not start cutting
tonight , Ha Ha !!!
I like how you kept the sweep Steve. On the others guys car I mentioned (forgot his handle here, but I think he's from your Apache territory) he sorta did it like a 55 would be done, the problem with that is that the front and rear openings don't match. At least on a 55 once the rears are cut the front and rears are much closer to being the same shape instead of looking like two different cars are welded together.
As far as mine goes, I'm not sure it would look right since my tires are 33's. That would require a pretty big cut, and would probably look pretty stupid. Plus, talk about NOT matching!
Old 06-18-2017, 10:23 PM   #14
1971BB427
1971BB427's Avatar
Member #16997
Dan, I've never thought the radius on most Tri 5 Chevys (after opening the rear) was the same as the front. Even a '55 is more squared up in front, and not the perfectly round radius that most gassers had at the rear. So matching never concerned me, and I usually cut the rolled lip off the rear of a '56 and put in a patch panel to make the radius look like a '55 that was radiused.
I had the same issue as a '56-'57 on my '63 Falcon, as it also had the sloped rear opening. I cut the opening, and then made up two little triangle patch panel fillers to go behind the tire and make it fit the shape of my slicks better.
1971BB427 is online now   Reply With Quote
Old 06-18-2017, 11:36 PM   #15
nad427
nad427's Avatar
Member #25732
Well I didn't mean to say 'exact' Vall. But look at how dorky and miss-matched the openings are when left stock.
I've never understood how GM could have left that, but what do I know except what my eyes tell me?
That's two different cars glued together!
On the other hand, once they are opened up things start to look more pleasing and natural.
As far as 56's go, the front to rear perspective gets a little more pleasing as far as a match because of the long sweep.
If a guy starts cutting he has to be really careful not to disturb that.
This one isn't TOO bad. but it's approaching the edge. I'm sure you'll understand.
Old 06-19-2017, 09:42 AM   #16
1971BB427
1971BB427's Avatar
Member #16997
I always thought the '55 Nomad had the perfect front rear wheelwell openings. They match up much better than the other models ever did.
I just never liked that trailing edge opening on a '56 Chevy when it's radiused. It just looks like too much open space back there.
Old 06-19-2017, 03:59 PM   #17
nad427
nad427's Avatar
Member #25732
I understand what you're saying, and mostly agree. If a guy is to cut them, like I said earlier it pays to be careful. Otherwise things get out of whack in a hurry.
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
