Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > This is a list of our Official Sponsors , Quality 55-56-57 parts Click Here > Classic Performance Products
Classic Performance Products This special area of the Forum belongs to Classic Performance Products, Members can ask questions and get answers about Classic Performance Products, parts and policies, and get free Tech support about Classic Performance Products only. Post about any other company’s products or services will be deleted if posted in this forum
Old 10-30-2016, 10:54 PM   #11
Originally Posted by jj357t View Post
I just installed my 500 box and sure as heck, it leaks on the pressure fitting. Can someone tell me how to contact CPP and how i get the cone out of the steering box?
Contact CPP: http://www.classicperform.com/contact.html
Old 10-30-2016, 11:51 PM   #12
jj357t
Member #24258
Thanks Don, can you tell me how to get the cone out of the steering box. It seems like the solution is to replace it so you can tighten the inverted flare onto it?
jj357t is offline   Reply With Quote
Old 10-31-2016, 12:02 AM   #13
If it hasn't been mentioned, CPP has a longer inverted flare so the fitting will tighten down enough.
You can thread a tap or "easy-out" into the flare, clamp it with some vice-grips, and tap the flare out of the box. Their not very tight in the box.
Old 10-31-2016, 01:39 AM   #14
Mel56
Mel56 has made a donation to the forum!
Mel56's Avatar
Member #2020
I too recently purchased a CPP 500 Power Steering box and also had a problem with the high pressure hose leaking. The problem is the bore on the high pressure side is too deep. Yes, I contacted CPP and they sent out a new longer inverted flare insert that replaces the one that came with the 500 box.
We weren't comfortable trying to dig the shorter one out so, I ordered new power steering hoses with deeper fittings.
I just completed this today but, because of rain, I could not take the 56 out on a test drive. But, when I start the car the hoses no longer leak.
The fittings should not bottom out on the box. You should be able to see a thread or two. If it bottoms out, most likely the hose will leak. The fittings cannot complete a tight seal when it bottoms out.
Mel
Mel56 is online now   Reply With Quote
Old 10-31-2016, 10:23 AM   #15
jj357t
Member #24258
Smile
Thanks Don & Mel, I have contacted CPP and am waiting for their reply. I also sent an email to Ecklers as they must know about the problem and sold the entire kit to me and did not mention it.
I am also going to see if I can just get either a new hose or coupler locally.
Thanks for the help!
Old 10-31-2016, 11:01 AM   #16
TheHotrodHandyman
TheHotrodHandyman's Avatar
Member #8438
I have installed several CPP 500 boxes and had this problem with only one. I took the brass seat out and placed a copper sealing washer under it, Put everything back together and problem was solved.
-Bruce
Old 10-31-2016, 11:12 AM   #17
jj357t
Member #24258
Sorry if this sounds stupid but, what do you mean by copper sealing washer?
Old 10-31-2016, 12:21 PM   #18
TheHotrodHandyman
Member #8438
Like what you put on a rubber brake line to caliper connection but not the same size.
-Bruce
Old 04-17-2017, 12:58 PM   #19
tekctrl
tekctrl has made a donation to the forum!
tekctrl's Avatar
Location: Fairview Heights, IL (12 mi's east of the St. Louis arch)
Member #24553
Originally Posted by westbilly View Post
Late to this thread but I just purchased ans installed a CPP 500 box and the high pressure hose also leaked at the box.And yes, the brass seat or cone inside the box was only sealing half way around. I contacted CPP(Chinese Performance Parts)and the promptly sent a new aluminum seat with rubber o-rings to replace the brass one. After the repair the high pressure hose still weeps.
After reading all the post here it would seem that CPP would address the problem at the root cause ie manufacturing process and correct the process.
Hmmm...a known problem of several years duration, and which has been the subject of repeated comments online here and elsewhere, yet the problem remains uncorrected at CPP. This is beyond a deficiency in customer service. This is well into "we know about it but aren't going to do anything about it because we're making more profits by selling the fix kits" and seriously disappointing, CPP.
I too had the same issue; leaking (squirting) pressure line in a brand new CPP box using the brand new CPP hose. The provided fix corrected the problem. However, it should have been corrected loooong ago with the manufacturer using a correctly machined/inserted brass flare seat. The fact that it remains uncorrected after all this time reflects very poorly on CPP's commitment to quality.
For grins and giggles, I'm attaching a pic of the brass fitting which I removed from the 500 box. You will note that, as described in other threads both here and elsewhere, the seat bears the imprint of the flare only half-way around the circumference. As a CPP customer, I'm very happy that the fix corrected the problem but very unhappy that the problem remains even years after being identified.
American Tri-Five Association Member!
tekctrl is offline   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
