Brace or not - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Metal Fabrication & Repair Questions > Metal Fabrication and Repair Questions
Metal Fabrication and Repair Questions Ask all your Metal Fabrication and Repair Questions.
Old 06-18-2019, 01:17 PM   #1
wheelie
Member #50208
Default Brace or not
Hello, new here and have seen differing opinions on trunk floor replacement.. on other sites...the new 57 2 door sedan I just got came with a Classic Industries trunk floorpan / mini tub kit...
It appears I will have to raise the body enough to install it from the bottom? Or remove the tub from the frame.... some have mentioned bracing the tub so the qtrs don’t sag, others say you don’t need to on a POST car...those who have done it please run me through the procedure.... car is now just the tub and doors.... so lifting off frame would just be steering and 12 bolts... thank you
wheelie is offline   Reply With Quote
Old 06-18-2019, 02:56 PM   #2
I have mini-tubbed several sedans and a couple hard tops there is no need for bracing when just doing the tubs and trunk floor. I cut out the old stuff, jack up body, slip in floor, set body back down, fit and weld in floor, then put in the tubs.
Old 06-18-2019, 07:59 PM   #3
some have mentioned bracing the tub so the qtrs don't sag, others say you don't need to on a POST car
My thought on quarters sagging is that they will do that over time if there's lots of rust damage in that area - or a bad repair. Look for that already being there. If half solid they shouldn't sag during your repair. If there's a problem then that's another repair to do.
Put the trunk lid on and line it up to the quarters and tail pan best you can before cutting anything off. Then use it to align the new tail pan and tail pan brace, which is probably part of your repair. Use tack welds or sheet metal screws to hold everything together and check alignment of the new pieces. Then finish weld, partial disassembly required.
Old 06-18-2019, 09:21 PM   #4
wheelie
Member #50208
[QUOTE=Rick_L;2246120]My thought on quarters sagging is that they will do that over time if there's lots of rust damage in that area - or a bad repair. Look for that already being there. If half solid they shouldn't sag during your repair. If there's a problem then that's another repair to do.
the trunk floor is very solid , but someone did a poor weld job on the spare tire delete patch, then drilled a few holes here and there over the years , then sprayed a bunch of undercoat on it .... i told the previous owner I was going to mini tub it , and he told me he already had the complete trunk floor mini tub kit , he was planning on doing , but never did ... he had already paid $1100.00 for the panel kit so I might as well use it ...
so no rust sag now , so I should be ok then , thank you guys for your help... ....
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
