Radiator install - Page 2 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Stock Chevy Discussion 55-56-57
User Name
Password
Stock Chevy Discussion 55-56-57 Stock Chevy Discussion, 55-56-57 Ask your Questions or help others with answers. Or any general Talk about stock Chevy's
Parts on Ebay
Reply
Thread Tools Display Modes
Old 04-16-2019, 12:23 AM   #11
Had a few Tri 5's
Senior Member 1 Gold Star
Had a few Tri 5's's Avatar
Member #6536
Default
Make sure the fan sits with the shroud in the middle of the fan blades. If it is in too far it will not pull air like it should and can actually be a detriment.
Had a few Tri 5's is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-16-2019, 02:16 AM   #12
johnonetrillion
Senior Member 4 Gold Stars
johnonetrillion has made a donation to the forum!
johnonetrillion's Avatar
Member #10655
Default
Quote:
Thanks for the tip. There looks to be a small amount of adjustment forward/back on this one.
I can't actually figure why a shroud was on this car in the first place. It's was a cool climate car its whole life ... but I certainly found that it got hot on hot days driving the west coast last year.
Radiator is now back from the shop – they guy said it was dirty and a few of the pipes blocked ... also repaired two small leaks that sprung under pressure ... but did not say it was a real mess. Kind of hinted to me that something else was contributing to the o/heating. We'll see.
johnonetrillion is online now   Reply With Quote
Old 04-16-2019, 08:15 AM   #13
YOUNG57
Member #22990
Default
Good point. I retract my earlier statement to place the radiator from the fan. With a shroud that measurement is irrelevant. It is more important to have the fan half in/half out of the shroud rear opening.
YOUNG57 is offline   Reply With Quote
Old 04-18-2019, 02:59 AM   #14
johnonetrillion
Member #10655
Default
Ok, I have the radiator back in.
The shroud is as far forward onto the radiator as it can go, and this assembly as far forward against the radiator support bar as it can go – and I'd say only 1/3 of the fan width is clear.
Is that enough?
If not, I will have to remove the shroud and take 1/2" off the entire front edge of the thing to allow it to move forward?
Road testing the car tomorrow to see how it goes and checking the coolant – maybe that will hold my answer.
Old 04-18-2019, 04:57 AM   #15
Nosee_Parka
Senior Member
Nosee_Parka's Avatar
Member #34133
Default
Hey John,
Would this be of any use to you, haven't used it myself.
http://liquidintelligence.com.au/pro...m-cleaning-kit
Was there much gunk in the radiator when pulled apart?
Maybe there is a deeper issue in the engine block.
Chris.
__________________
"HP" Only stands for "Has Potential" Until you start it up and floor it.........
I fill my wallet with money,
I fill my car with fuel,
I fill my mind with memories because that's the only one that will last............
That and the photo's.
2015 Tri-Five Nationals Attendee #387
No car though, couldn't fit it in a suitcase............
2017 Tri Five Nationals Attendee #1620
Again No Car......... One Day.
Nosee_Parka is offline   Reply With Quote
Old 04-18-2019, 05:07 AM   #16
angs1957
Super Moderator
angs1957 has made a donation to the forum!
angs1957's Avatar
Member #2237
Default
Quote:
The shroud is as far forward onto the radiator as it can go, and this assembly as far forward against the radiator support bar as it can go and I'd say only 1/3 of the fan width is clear.
Is that enough?
Road testing the car tomorrow to see how it goes and checking the coolant maybe that will hold my answer.
The shroud sits so half of the fan blade is covered.
__________________
angs1957 is offline   Reply With Quote
Old 05-16-2019, 03:03 AM   #17
johnonetrillion
Member #10655
Default
Quote:
Originally Posted by Nosee_Parka View Post
Hey John,
Chris.
Hey Chris
I don't really know much about this sort of stuff. Has anyone used it on an old block?
The weather is cool now, so when I run it on the highway is barely gets to the half mark on the temp dial. In fact, it was so cold and wet on a drive last week that it barely cracked the quarter mark – it was like it was UNDERheating.
Will look at it all again in summer.
Also ... any takers as to whether having 2/3 of the fan covered by the shroud is still ok?
Old 05-16-2019, 05:28 AM   #18
angs1957
Super Moderator
angs1957's Avatar
Member #2237
Default
The shroud sitting 2/3 over the blade maybe OK, I`m sure you`ll find out when summer comes round
__________________
Old 05-16-2019, 09:14 AM   #19
johnonetrillion
Member #10655
Default
Does anyone have specific experience of this – one way or the other?
Old 05-16-2019, 12:03 PM   #20
Had a few Tri 5's
Member #6536
Default
John, look at this quick explanation of how the shroud placement affects performance>>>>
https://www.flex-a-lite.com/blog/the...roud-position/
It might make a difference if you still run on the hotter side. Remember, they were originally designed without a shroud. If you are really getting hot with a close to stock configuration, you might have another issue that you are trying to cover with a fan/shroud.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
US Radiator, Desert Cooler Optima Radiator augustine Cooling Systems, Radiators, Fans / A/C 11 10-30-2019 09:59 PM
upper radiator hose w v8 and 6 cyl radiator jewel57 Cooling Systems, Radiators, Fans / A/C 24 10-31-2012 02:24 PM
Champion radiator radiator hoses 55_chev LS & LT Installation Questions and Answers 21 06-09-2012 09:44 PM
Radiator baffle removal when relocating radiator? Scott Phillips Cooling Systems, Radiators, Fans / A/C 7 04-02-2012 10:52 PM
WTB: 57 radiator / radiator shroud Mumpsdba Classifieds section of Trifive , For Sale items ONLYl, DO NOT POST WTB OR TRADES IN THIS SECTION 4 07-19-2011 10:55 AM
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
