engine id. - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Stock Chevy Discussion 55-56-57
User Name
Password
Stock Chevy Discussion 55-56-57 Stock Chevy Discussion, 55-56-57 Ask your Questions or help others with answers. Or any general Talk about stock Chevy's
Parts on Ebay
Reply
Thread Tools Display Modes
Old 05-15-2019, 05:54 PM   #1
allen_
Member
Member #10661
Default engine id.
55 belair owned for 14 years. valve cover screws are off set. best i could find was chevy used these from 55 to 59. stamped on left front of block V1001UA. have not been able to read numbers on rear. can someone id this motor using this code? it is a small block. thanks for any help.
allen_ is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-15-2019, 05:58 PM   #2
TheHotrodHandyman
Trifive Leaders Club
TheHotrodHandyman has made a donation to the forum!
TheHotrodHandyman's Avatar
Member #8438
Default
Sounds like an early set of heads on newer short block.
__________________
-Bruce
TheHotrodHandyman is offline   Reply With Quote
Old 05-15-2019, 06:14 PM   #3
davidc
davidc has made a donation to the forum!
davidc's Avatar
Member #9348
Default
This might help....
http://www.nastyz28.com/gm-chevy-cod...s-suffix-9.php
__________________
davidc is offline   Reply With Quote
Old 05-15-2019, 07:04 PM   #4
56 2x4
Senior Member 3 Gold Stars
56 2x4's Avatar
Member #2648
Default
Even with a concise descriptor, it will not be verifiable without double checking the numbers in back. You're going to have to find the rear numbers and read them. I normally cannot read them either. But you can take a picture of them with a small consumer digital camera with a flash.
__________________
You get much more in a smart new
Chevrolet Station Wagon!
Assembled April, 1956, Pinecrest Green/Sherwood Green, green interior with factory green padded dash, green EZI, Super Power Pack RPO 411, Powerglide, Wonderbar
56 2x4 is offline   Reply With Quote
Old 05-15-2019, 07:06 PM   #5
557B210
557B210 has made a donation to the forum!
557B210's Avatar
Member #5571
Default
Get the casting number and date code off from the rear bellhousing flange on the block.
__________________
______________________
* See my painfully slow and overly detailed build thread here: https://www.trifive.com/forums/showthread.php?t=79427
* I have a vast data base of TriFive restoration & upgrade articles for our members' use...Send me a PM with your EMAIL ADDRESS and subject matter...See this link:
https://www.trifive.com/forums/showthread.php?t=175309
* Contact me by PM to purchase your PHR's Project X and TriFive Gasser Building CD's
_________________david aka POPS & sherry
557B210 is offline   Reply With Quote
Old 05-15-2019, 08:15 PM   #6
upsrod
Senior Member 1 Blue Star
Member #49008
Default
I would like to see the casting date on the back of my 283. If I take the access plate to get to the trans bolts off, can I see the motor casting date with the plate off?
upsrod is offline   Reply With Quote
Old 05-16-2019, 07:39 AM   #7
hedotwo
Senior Member
hedotwo's Avatar
Member #44136
Default
I have a USB endoscope/boroscope inspection wifi camera that I use all the time ($29 on amazon) for various things, cars or not. It'll snake around and show you things you'd never see otherwise, and has bright little LED lights. Easy to use. Guarantee it'll let you see those casting numbers on the back of the block no problem.
Rich
hedotwo is offline   Reply With Quote
Old 05-16-2019, 10:33 AM   #8
upsrod
Member #49008
Default
Thanks Rich.
Old 05-16-2019, 11:55 AM   #9
allen_
Member
Member #10661
Default engine id
looks like i may have to wait. thanks for the info .
Old 05-16-2019, 12:52 PM   #10
55wagoncrazy
Stainless Trim Restoration
55wagoncrazy has made a donation to the forum!
55wagoncrazy's Avatar
Member #22828
Default
Some things you can see easy. Are there side motor mount bosses around the front freeze plug on the sides of the block. If so it is a 58 or later cast block.
If there are no side mounts, check and see if the road draft tube is on the driver side where the oil filter is on all 56 and later V-8 motors. If it has a oil filter there it is 56 or later cast V-8. If there is a road draft tube it is a 55 V-8 and it is one year only.
The number you listed could be a rebuilders # and there is no way to trace it to a year of motor, until you get a casting date and # off the rear of the motor.
Mikey
__________________
40 Years of Professional Restoration of anything on a 55-57 Chevy
Michael Domoracki (Mikey)
The Stainless Shoppe Restorations
N8143 State HWY 55
Seymour WI 54165
Email: [email protected]
920 833 0290 Sunday -Friday 8AM till Sundown. Closed Sabbath until Sundown Saturday night
55wagoncrazy is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
An engine is an engine is an engine........... max46 Chit Chat Area, Anything on your mind goes here. 12 01-19-2017 04:56 PM
Corvette engine. Is there a differance in a corvette engine and a regular engine? rayharris Chit Chat Area, Anything on your mind goes here. 17 08-02-2012 08:53 AM
Engine Block ID Help twincc55 Super Stock / Pro Street and Modified Discussion 55-56-57 2 05-31-2008 08:44 PM
Engine ID Buggrn56 Stock Chevy Discussion 55-56-57 3 12-24-2007 01:13 PM
Need help with engine ID # travis Stock Chevy Discussion 55-56-57 1 09-23-2007 07:24 PM
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
