Old 05-15-2017, 03:44 PM   #21
Mr. Sinister
Mr. Sinister's Avatar
Member #8778
Originally Posted by HotRod Junkie View Post
That is way cool ! !
What is the process to add the disc in the rear vs the drums in regards
to the master cylinder, Just add a proportioning valve ?
I have CPP aftermarket front disc already and their MC as well.
Also , are you planning on hooking back up an emergency brake ?
I have power discs up front and a 50/50 dual master cylinder already, but I'm changing out the existing distribution block (came on the car and may not be correct for dual discs) for an adjustable proportioning valve, adding a line lock for the front, and all new hard lines. The brakes on this car have always been trash (rears never really worked, and the fronts wouldn't hold the car for burnouts), so this should be night and day.
I am not going to use the emergency brake for the time being, as it's never worked either. I may do this down the road: http://www.speedwaymotors.com/Pinion...ake,44784.html
Mr. Sinister is offline   Reply With Quote
Old 05-16-2017, 11:22 AM   #22
HotRod Junkie
HotRod Junkie's Avatar
Member #33509
Good Info! Thanks again!!
HotRod Junkie is offline   Reply With Quote
Old 06-14-2017, 09:01 AM   #23
Mr. Sinister
Member #8778
ALMOST done. We've been chipping away at it little by little as time allows. I had to get new stainless flex lines for the rear brakes, as the stuff Quick sent was some oddball size that wasn't going to jive with everything else.
Updated pics here: http://imgur.com/a/jTJSG
Old 06-19-2017, 09:20 AM   #24
Mr. Sinister
Member #8778
Welp, everything is all buttoned up!!
Well, almost. Got a leaky fitting on the outlet of the line lock that needs addressing. Started out ok, but after a few stops, the pedal was going to the floor from what I assume is air getting in the system. Other than that, all seems great.
http://i.imgur.com/oWPntS1.jpg
Old 06-19-2017, 06:39 PM   #25
carls 56
carls 56's Avatar
Cool
nice work, does look good under there too. cool wheels.
"DRIVE AND ENJOY THEM WHILE YOU WORK ON THEM, LIFES TO SHORT"
my toy: 56 4dr 210
ARMY NAM VET (so proud)
carls 56 is offline   Reply With Quote
Old 06-20-2017, 01:09 PM   #26
Mr. Sinister
Member #8778
Thanks!!
Same wheels it's always had, but they do look cooler with the 3" lugs and exposed axle ends.
Old 06-20-2017, 02:09 PM   #27
fifties-forever
fifties-forever has made a donation to the forum!
fifties-forever's Avatar
Member #26998
I had some issues with my line lock leaking as well. Ate some of the paint off my inner fender.
I put all new Wilwoods on mine during the QP install and had a lot of issues with air in the lines.
Good luck and great progress so far!
Tom
If you can read this in English...Thank a Veteran...
Land of The Free BECAUSE of The Brave.
RIP Dad, Eddie E. Tenhaeff, POW, WWII, Sgt. US Army Infantry, German Concentration Camp Survivor.
U.S. Army, 11th Armored Cavalry Regiment, 4th Infantry Div. Armored Reconnaissance Specialist.
fifties-forever is offline   Reply With Quote
Old 06-21-2017, 01:24 PM   #28
Mr. Sinister
Member #8778
Mine is dripping down on the steering box, so no biggie there.
We're going to work on it tonight. Pull the line lock, see if we can't get it to seal up. If not, I may just put a union in it for now and get it replaced under warranty. Then thoroughly bleed the brakes. Fingers crossed!!
Old 06-22-2017, 08:36 AM   #29
Mr. Sinister
Member #8778
It's the line lock. Pulled the fitting off, used some Leak Lock on it, put it back in, cranked it down as much as we were comfortable with, and still gushes fluid. Looks like pretty poor machine work with a really dull tap on the output threads. Gonna return it to Summit and get the Hurst unit instead. But for now we put a union in its place so I have brakes. I might even get to test drive it if it ever stops raining here.
Old 07-15-2017, 01:35 AM   #30
classic gary
classic gary's Avatar
Member #5707
You mentioned turbo'd LS, where are you going to put the turbo/s? I'm trying to place twins under the hood of my '57. Ive got three choices, I think. Just looking for ideas.
classic gary is offline   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
