Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Interiors Questions and Answers
Interiors Questions and Answers Ask all your Interior questions here, Custom Interiors or Original Interiors this is the place to get advice and give advice.
Old 06-13-2017, 11:31 AM   #1
Mr. Sinister
Mr. Sinister's Avatar
Member #8778
Default Question for bucket seat guys
I just picked up a pair of bucket seats (no idea what they're out of, but they're in great shape and are comfortable) with tracks. Everything is manually adjustable, so I'm good there. I got some universal brackets that you can adjust the height a little with for the front, and I figure I can whip something up for the rear if necessary.
I'm wondering if you guys are finding you had to make spacers to raise your buckets up, of if they pretty much dropped right in? Sitting in the driver's seat on the floor, it's hard to tell how close they are to where they'd need to be. Won't know for sure until I go to mount them, I suppose.
Seats: http://imgur.com/I7dytCd
Mr. Sinister is offline   Reply With Quote
Old 06-13-2017, 12:12 PM   #2
chevman57
Sr. Administrator
chevman57 has made a donation to the forum!
chevman57's Avatar
Member #264
Every set of seats is different on the mounting due to how many different floor configurations there is.
http://s1181.photobucket.com/albums/x437/chevman57/
http://www.cardomain.com/id/chevman57
http://www.trifive.com/forums/album.php?albumid=1177
1957 2dr sedan Bel Air, owned since 1978
1972 Chevelle Malibu, awaiting rebuild,owned since 1979
chevman57 is offline   Reply With Quote
Old 06-13-2017, 07:53 PM   #3
nad427
nad427 has made a donation to the forum!
nad427's Avatar
Member #25732
The stock seats in these cars sit too high in my opinion. I'm only about 6 feet, and when I get into a stocker my head almost hits the headliner. My upper body seems too high in the window also, I don't like it.
Before starting to make mounts for the buckets in my 56 I struggled for two days figuring out the right height by using 2x4 blocks and other pieces of wood.
Once I found THAT then came the next struggle,
After mentally going through 6 or 8 different over-complicated designs of mounts I finally did the simplest and easiest. Since my car is a 'simple' hotrod and not a show piece I found it easy to do. My seat itself brackets are similar to yours so I just took cut pieces of angle iron (four pieces per seat) and welded and bolted them to the floor. That allowed me to stagger the hole height, since our cars' floors drop altitude as it gets closer to the door. When I go to do carpet all I'll have to do is cut slits where the angle sticks up, which is plenty better than trying to find bolt holes after the carpet is down IMO.
For the sides I cut and bent these covers out of flat sheet of 16 gauge to finish off the sides to hide the angle and the under part of the seats.
Am curious to see what you end up with.
nad427 is offline   Reply With Quote
Old 06-13-2017, 08:32 PM   #4
You'll need to do something with your seat mounts to deal with the floor.
The floor is 1-1/4" higher next to the trans tunnel than at the original seat mount.
On mine I used a 1-1/2" square tube on the outside mount, and the inside mount was made from 1/4" thick flat bar. This made the seats I have sit level since they were designed for a flat floor. They are from a late 90s Chrysler. They are 6 way power. I found that midway up on the height adjustment was roughly the same as the stock seat height. I don't remember how much adjustment the seat has but I can get lower than stock, or tilt the seat a bit if it's not at the lowest it can be. I have no desire to "lay back" the seats as some do, but a "bit" is good for me - like 1" difference from flat.
I would recommend that you build the mounts as low as possible or close to it while keeping the seat level. You can always add some spacers if too low.
My outside mounts have brackets that bolt to the original seat mount holes, which are reinforced in the floor. On the inside, I extended that mount back to where it bolts through long brace under the floor. The seat has an inner seat belt mount on it, so securing the rear inner mount to good structure was important to me.
Rick_L is offline   Reply With Quote
Old 06-14-2017, 08:42 AM   #5
Mr. Sinister
Member #8778
Thanks fellas. I bought a pack of 2" body washers to use as shims to determine how tall the eventual risers will have to be. My front mounts are angled steel with 3 levels of holes in them for height adjustment, and I can compensate for the floorpan angle from there with risers if need be.
Are you guys finding the original bench rear mount hole works for locating the rails, or do you end up too far forward or backward? The seats I bought have a pretty good amount of adjustment front to back.
Here's the front mounts I bought to deal with the vertical tabs on the rails: http://imgur.com/fQvAthf
Old 06-14-2017, 09:27 AM   #6
nad427
nad427's Avatar
Member #25732
That's interesting. Didn't know that those were available.
Another thing I didn't mention is the fact that I personally don't like it when the seats themselves stick up too high in the windows. For some reason I like it when you can look all the way through the glass and see pretty much nothing. The only exception of course is if one of these cars has a cage in it. I had to compromise on that some, and it made my height struggle even more so. My seats have removable headrests so that part made it a little easier by allowing me to pull them if I chose.
Old 06-14-2017, 10:05 AM   #7
Mr. Sinister
Member #8778
They're technically for side mount seats, but I figured they'd work well for my needs. They should give the the adjustment needed to level the seat, and compensate for any angle in the floorpan near the tunnel.
I'm with you on the clean line of sight through the window. I already pulled the headrests off. I'd like to actually sit a little higher in the car than my bench seat allows now, but the bench springs are also fairly worn.
Old 06-14-2017, 06:43 PM   #8
nad427
nad427's Avatar
Member #25732
Well to be honest I pulled mine long ago also. They are very comfortable, but I just can't stand look of them when viewing through the back glass from behind, or the side for that matter. Luckily for me the tops of my buckets line up right at the tops of my doors. Any higher and I'd be disappointed.
Now that you say it, all of the tri5's I've been in over the last few years have been freshly restored or built. It could be that fresh foam was causing me to feel like I had to bend my neck to keep my head off the headliners. Maybe with worn in foam it wouldn't be so bad. Whatever the cause I was determined that my car wasn't going to be that way.
Way back in 72 I bought a 68 BB Chevelle, and I still remember to this day how much I liked sitting down lower in that thing over my old 56 I sold to help me get the Chevelle.
Old 06-15-2017, 08:27 AM   #9
Mr. Sinister
Member #8778
The difference is probably intended purpose. Tri-fives were more or less family cars thst guys have turned into muscle cars, whereas Chevelles were designed to be muscle cars. So you're upright and proper in a factory tri-five seat, and you're nice and low in a Chevelle. Even the benches feel lower in muscle cars.
Old 06-19-2017, 09:22 AM   #10
Mr. Sinister
Member #8778
I picked up some 1.25" thick aluminum flat stock to use as spacers for the outside mounts, and to help distribute the weight a bit. I plan to tackle this some time this week if the temperature and humidity take a break.
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
