1957 2dr ht The piece of chrome trim on the inside of the car where the side quarter window meets the back window it is wide at the bottom with two screw mounting tabs and narrows at the top with a screw mounting hole. When I line up the upper hole and what I believe to be the rear tap with the only hole I can find the front tab is just hanging in mid air with nothing to mount to. Does anyone know of any pictures showing all three mounting points, am I missing a bracket? Thank You
Banned
There is no place for the tab to mount to.Fellow members and I have had this discussion.Why....ask the designers.
Stainless Trim Restoration
The part you are refering to is the headliner finishing molding. The lower forward screw hole is most often not used. If it is, it will align to a hole in the inner corner felt retainer. What will hold it in place is the long painted garnish molding trim that finishes the top of the upholstry panel to window gap.
Mikey
55wagoncrazy
