What is this piece and where does it go ?
I don't recall an oil slinger on any of the 235s I've ever worked on.Oil slinger.
Is that the correct orientation in the picture ?You have not worked on enough 235s then, lol. All kidding aside, you don’t find them on all motors, and especially if they have been previously apart. Most scratch their head after the motor has been apart a while wondering if it’s for a 235.
Ordered!Yes. The snout of the balancer sits in the recess and holds it in place. Also, let me highly recommend that you drill and tap the crank snout for a balancer bolt.
With the crank snout threaded for a bolt, you can use a standard balancer install tool instead of pounding the balancer on with a block of wood and a hammer. Which by the way, is a two man job because you have to have someone with a big long pinch bar wedge the crank forward so you dont damage the thrust main bearing while you are hammering away.
This is the tool you can use to do the drilling.
Crankshaft Drilling Fixture Balancer bolt 283 327 250 235 261 230 215 194 Tool
Use this tool to help drill the snout of cranks on 194 230 250 engines. Also works on SBC 283 327 as well for 235 261 The cranks are not drilled from the factory and adding the 7/16 bolt hole will aid you on installation of the balancer and retention of it. Precision made to fit on the end of...www.12bolt.com
Thank you - awesome resourceThis is the crankshaft drilling guide that I made. It also doubles as a crankshaft turning socket and also as an alignment tool for centering up the timing cover to the shaft before you View attachment 386325
bolt the cover down. It is long enough to keep the drill bit on center and straight (I did use a 25/64 bit). I wrapped the tap shank in cardboard and let that center the tap in the hole so it doubled as a tap guide as well as a drill bit guide. I also ordered a tapered tap to make the tapping easier to do. A long taper on the tap makes it easier to keep the tap straight in the hole. My memory is failing me right now but I think it was a #3 taper. Be sure to use a cutting oil like Tap Magic or something similar. The photo shows using it as a tap guide to keep it straight. Once the tap handle bottomed out I removed the guide. By that time the starting threads were established and I continued tapping without the guide.
