These are the correct carbs for the 1957 Dual Carburetor setup. Only the rear carburetor has a choke. The progressive linkage allows that only the rear carburetor is operational until opening a certain amount at which point the front carburetor begins opening, continuing until both are fully open.
Left side:
Right side:
Air horns marked 6-1299:
Bowls marked 049:
Linkage:
Fuel and Choke lines:
Who re-did the carbs? I've got a couple sets I want to get done eventually, I want them properly "colored" Like yours. Are the passenger car wcfb's the same as the Corvette carbs?
thanks for info. great looking carbs too, thanks David. :tu
As far as I know, Corvette and passenger car WCFBs were the same. Weights are different 245hp vs. 270hp
The carbs in the last picture are not original. The primary to secondary linkage is 58 and later single quad. Ask me how I know. I have 2 58 single quads on my race car. A real rear dual quad has a secondary arm with 3 holes in it. The first set of pictures shows long arms on the secondary air valves. those are used on 58-61 270hp carbs( and 57 single quads). All 57 dual quads used short armed valves, some with a small weight like a 56 dual quad, but most with the larger weight, weather 245 or 270.
