replaced both rear full qtrs on the 57 from golden star, to me, they seem to be flared out too far over the wheel wells?...what should it be from tire to outside?...ed
Are you sure they are GS, those are normally not too bad in that area.
Sherman, on the other hand is really obvious. Post some pictures.
Stainless Trim Restoration
I have installed 4 pair of convertible ones and have another set to do on a car. What I can tell you is that the installer can make a big difference on how "pregnant" they appear. I don't have any to measure at present to help.
What you need to do is look inside the wheel housing and see how close the skin is to making contact with the inner rubber seal on the inner wheel housing.
I have not had any experience with 2DR SEDAN quarters to know if this is a problem with those.
Mikey
I have seen some of the 57 quarters and at least one of the manufacturers has the flair so far off as to be hideous. Makes the case for saving as much of a quarter as possible, particularly the flare.
