81 - 93 of 93 Posts
stock factory air cleaner should be black.
Discussion Starter · #82 ·
TY,
Ok, Time to go over the brakes. Just wondering if the 3200 model is the same as a Cameo as far as brake hardware goes. Ex. wheel cylinders, hoses, ect.
On the positive note, I started it for the first time in probably 35 years. Ran good, but I only wanted to let it run for a short time 'cause of no coolant in radiator.
Can't wait till it's road ready.
Discussion Starter · #83 ·
Ok, been thinking about putting power disc brakes on the truck (For Safety reasons). I was wondering how easy/hard it would be to change over. How much would I expect to pay. Can I use the original wheels, ect. Thanks for any help or advice.
Discussion Starter · #84 · (Edited)
Just wanted to post an update. Truck is running, sounds good, Will need exhaust. (Most of it has rust holes in it). All most all the metal underneath has just surface rust on it. (A lot of wire wheeling & Brushing ahead of me). Got new wheel cylinders & hoses. Brake pads look pretty good. (Quite a lot of pad left). Brake lines must have been replace with stainless lines 'cause there is no rust on them & they look like they were replaced before putting in storage. If I am looking right it seems like the lower radiator hose (Where it mounts to the pump is leaking. (The hose is new, but no compression spring in it). I cannot seem to find a "fixed" lower hose. They all are flex hoses & I'de like to keep the original look. Hopefully will have it road ready by spring. Seat has been reupholstered.
Once again thanks to everyone who gave me some input & advice on the truck.
good to hear your making progress. :anim_25: ------> hint:pics-1:
Discussion Starter · #86 ·
Ok it's been a while since my last post. (Got busy with other projects.) I went to put the new door panel on (from Ciadella) and they didn't come with original "c" clips molded into the panels. Any suggestions on how to attach them? I guess I could just glue the old clips to the new panels, or is there a better way? Thanks for any tips or help. It's slowly coming along. Hopefully in the next month or so I can get it on the road.:gba:
I will move back to top for you. :anim_25:
Discussion Starter · #89 ·
Ok, good news. Finallllly got her out for the first time in probably 35 -40 years. Everything went fairly good except 2 things:
1. It seems like it is overheating. The radiator is rebuilt, new thermostat, new hoses, ect. I only went about 10 miles round trip & the radiator was so hot I could not even get close to touching it, and there was very slight smoke coming from the oil fill tube. I cannot really tell for sure if it is overheating though because the temp guage does not work. (I have a new temp sensor on order.)
2. The steering is all over the road. I have brand new wide white radials. I checked the steering bow & aside from a very little bit of gunk that looked like wheel bearing grease it was dry. What kind of fluid does the steering box take? I've heard anything from 80/90 gear lube to chassis greese.
Thank you ahead of time for any tips or help. I can't wait to get it all dialed in & drive it without any worries.
Just read the entire post Great story getting your dad’s truck. I think your on the right track with the truck. Get it running and safe to drive it’s a process don’t get overwhelmed by it. You have a great truck to start with one thing to keep in mind there only original once. Sure it’s been repainted and has some rust issues but that’s no reason for a complete restoration. You can bring that truck back to it’s original glory and protect its value by not restoring it.
I did my first total restoration over 30 years ago and a hand full sense. It’s not always the way to go.
If someone wants a restored vehicle and can’t due most of the work himself your money ahead to buy one done. And then make small improvements to make it your own.
I understand this is your dad’s old truck you want to make it nice. Make it a nice old original truck.
Discussion Starter · #92 ·
Thank You 55carman. I think I will keep it the way it is. With the condition it's in now I won't worry about a small paint chip, stone hitting it.....ect. The only issue I have at the moment is it seems like it's all over the road. I don't know if that is just something the way the vehicles were back then. (I have not driven a vehicle from that era before), or if it can use an adjustment. I think my Dad would be happy i'm driving it, even though he never did. He bought the truck & put it in storage right away.
No those trucks are great driving trucks when the front end is nice and tight. I had a 57 back in the seventies everyday driver. Drove it for six years every day my only complaint would be no power steering.
I have a 57 I’m building now just put power steering on it. Haven’t made it’s first road trip yet but stay tuned it won’t be long. If interested check out my build. Proud owner of this 57 in this same section as you posted in.
81 - 93 of 93 Posts
