1 - 3 of 3 Posts
I need help i want to go with 20x10 in the rear of my car but , i dont know if they fit and i want 18in in front my car is all stock orginal i need sizes of tires to go with and back spacing etx.:p3:
Hello Ruben,
you will need to move the leaf springs,useing a pocket kit or inside the frame rails,also need to mini tub.
What size tire are you going to use,what width diff,this will need to be known so you can get the correct offset,there is a tire calculator somewhere on here
i used it and measured alot,the calculator is very accurate,fronts you can use the calculator for aswell.
gooduck
Nathan
1 - 3 of 3 Posts
