I believe the gauge won't be accurate Angelo....The resistance of the sender is not linear as the coolant temperature changes.
Pops, let me add a bit more detail.
The engineering term for these devices is a "thermistor" - a resistor whose resistance changes predictably over a range of temperatures. They're typically specified as change in ohms per one degree change in temperature.
For the moment, let's assume that spec is linear over the range of 100 to 220 degrees Fahrenheit. Looking at the specs we dug up the other day:
56 Chevy Electrical Sender for Temp Gauge (NOT the same as a 57)
½”-14 NPT Thread
100°F Ohm Value 469.20Ω - 312.80Ω
220°F Ohm Value 111.65Ω – 91.35Ω
57 Chevy Electrical Sender for Temp Gauge (NOT the same as a 56)
½”-14 NPT Thread
100°F Ohm Value 441.60Ω – 294.40Ω
220°F Ohm Value 88Ω – 72Ω
If you're a geek like me, you'll notice that the 57 Chevy 220 degree spec is actually 80 ohms +/- 10%. Likewise, the 56 220 degree spec is 101.5 ohms +/- 10%. The lower spec is much looser (+/- 20%).
So, taking the nominal values for each, we find:
(101.5-391 ohms) / (220-100 degrees) = -2.41 ohms/degree F (for '56)
(80-368 ohms) / (220-100 degrees) = -2.40 ohms/degree F (for '57)
Now if we plot this on a traditional x-y chart (x=temperature, y= resistance), we'd see a) the slope of the two lines are only slightly different (-2.41 vs. -2.40), and b) there's an offset between them. (21.5 ohms and 23 ohms at either end)
Now, if the measurements I'm proposing reveal the relationship is indeed linear (constant -2.41 or -2.40 Ω/°F over the range), the lines will be straight. Then, you ought to be able to fudge it by putting a 22 ohm resistor in series with a '57 sending unit to make a '56 gauge read correctly.
But, if we plot the measurements on the above-mentioned chart, and the lines aren't straight, a 22 ohm resistor would still work, as long as the difference between the lines remains constant (21-23 ohms). If not, then all bets are off.
Anyway - I'm going to check with a buddy of mine to see if he has a NOS '57 sending unit I can borrow for this test. If not, I'll use an aftermarket I've found to work well in my '57 (BWD WT203). And, we'll see what's what.
Yeah - living up to the name "stoveboltgeek"...
John - if there's an electronics supply store in your area, get a 22 ohm resistor (1 watt, just to be on the safe side) and see if your gauge reads correctly when warm. I'd go with a 5% or tighter tolerance, but the composition (carbon, wire-wound, film) doesn't really matter.
Also, this conversation does make me wonder if the guy who sold you this car got rid of it because the temperature gauge said the engine always ran too hot, and he could couldn't figure out why.
