I have a 56 truck with a 235 straight 6 and 3 on the tree. I realize it does not have synchros. I am having issues with it grinding while trying to go in first gear from a stop. No grinding in other gears and shifts well too. Not sure if there is an adjustment or if there is a problem or maybe it is what it is. Thanks.
Chris
RIP: 10-27-2018
You are correct that first gear doesn;t have syncro's but second and third does. I would suspect that your clutch is improperly adjusted and not totally disengauged if it grinds at a full stop with the clutch pushed all the way in.
