So I have a fresh rebuild 4160, i smell gas or really rich smell at idle. Carb runs great no leaks and everything appears to be functioning properly you can smell the "gas" with the air filter on or off and the filter is open topped and sides. Any thoughts:gba:
Big difference between the smell of raw gasoline and running too rich..... are you smelling raw gas? If yes you have a serious problem and need to locate the source before it catches fire....
Start at the fuel tank sending unit and work forward......
