Hello, I just picked up a 454 with the casting number 14015445 on it.And the head casting of 353049.Also the number on the intake is 3883948.Any help with this motor is welcome.I plan on installing it in my 55 210.What am I getting myself into? Thank you Patrick :gba:
14015445- 2 or 4 bolt main 454 produced from 1978-1990
heads 353049-oval port open chamber 1973-1984 - 454
intake 3883948- 396 cast iron Rochester 4 bbl. 1966-68
Good luck,hope this helps.
Big Bob:flag4::bowtieb:
Banned
049 and 781 are the best oval port open chamber heads GM ever made really respond well to 2.19/ 1.88 valve swap.
It's no pot of gold. Likely from a truck, suburban, or RV since the block is too new for a car. Check out the condition for spun bearings etc. Check your local actual sale prices. Check some shop labor and parts prices too. Also check the stamping on the deck surface behind the alternator and date code on the belhousing lip at the back of the engine. In OH that engine would bring 300-500 running. I'm not saying it's juck just don't get taken.
That block is far less plentiful than the car blocks. Some of them ended up in SS454 pickups. I have an empty one of them blocks that I've hung onto for years, just for that reason.
If yours turns out to be the 2bolt version it don't matter. You can still build high horsepower without worries. Pick out a good cam and intake, plus headers and you'll have enough power to put your car in the ditch if you're not careful.
