1 - 2 of 2 Posts
is this an unheard of swap? what all is needed, there are lots of these trans out there, and quite easy to rebuild, but is there some type of aftermarket kit to install with out oem computer?
There are controllers out there.
I guess my thought is that if you have an engine that came with a 4L60E behind it you should use it if you want an automatic. The accompanying thought is that if you have an engine that didn't come with an electronic trans, then use a 700-R4 or a 200-4R. I just think that the aftermarket contoller is way too high priced to give you the bang for the $$$.
I don't know if you're buying new or used. If you're willing to go used you can get a used engine/trans combo for about the same price as the controller/harness/trans.
1 - 2 of 2 Posts
