1 - 3 of 3 Posts
· Registered
I am missing the emergency brake. I have a 12 bolt rear, and I found a 55 emergency brake setup. I need everything. They look the same, are the parts interchangable. I know the rear cables will be different.
Any help is appreciated.
· Registered
I think it will all be the same but I'm not absolutely sure. What might be different is the pieces on the firewall, everything else should be the same.
The rear cable will probably work too but you may have to make a small modification at the ends, as the springs may need to be trimmed, etc.
1 - 3 of 3 Posts
