Looking for recommendations on a chrome master cyl and chrome booster for a 55 belair. 4 wheel disc brakes. Also want to upgrade the front brakes . Thanks for any help
BOOSTER
Djmc, Whatever you get DON,T ,get the small booster!It looks cool but the larger booster will make the car much pleasnanter to drive. Ask me howI know! DICK:shakehands::anim_25:
Check out the boosters from our sponsers...should fine what you want there....:anim_25:
:gba:
bowtie-trifive
The car I'm working on already has 4 wheel disc with small booster and it stops worse than the drum brake car I have. It has g m type calipers - front rotor is 11 inch. I put it on the lift and put it in gear -found out the rear axles are bent so I'm gonna replace that. It was pushing the rear calipers back and causing the pedal to be spongy. How big can I go on a booster? It's a small block with aluminam valve covers.
