Good Morning Guys! I just got a replacement clock at Eckler's SAD sale and need to know where to connect the Red and Gray wires from the clock's harness. The CLOCK terminal on the fuse box is being used for something else, something with the A/C I think, so where can I connect these leads to get the clock and light working?
Thanks very much!
What kind of wiring harness/fuse block do you have? Apparently it's not stock because the clock never had a fuse. It was connected directly to the red wire circuit. Some fuse blocks will have a socket that you can plug a terminal into called "bat" that is constant power. If so, use an inline 5 amp fuse. The gray wire connects to the dash light circuit and there may be an empty terminal on the headlight switch next to the gray wire labled "instrument". ....http://www.trifive.com/garage/55%20Chevy%20Assembly%20Manual/12-6.gif
