'55 Factory (repro) A/C Vent Installation
8436 Views 13 Replies 11 Participants Last post by  Jim '57
11
I cut the holes in my dash today for side factory a/c vents.
Here's the cutouts and the saw I used. It's a 3 1/2 Milwaukee hole saw that I got at Home Depot and it was perfect.
And, here are the factory repro vents installed:
Only a few things to say about how to install them.
Just mark the center of the hole where the instructions say to.
Center punch the mark.
Hold the drill as straight up and down in relation to the dash as you can.
Drill until you expose the vertical seam pinch weld at the top of the hole and stop.
From the back side, cut the vertical seam pinch weld.
Continue to drill until you expose the seam pinchweld at the bottom and stop. You are done drilling.
Cut the pinch weld from the back and remove the cut out.
Do a trial fit and trim the hole a little if necessary.
I used a 1/4" shank carbide burr to cut the inside pinch welds. It was fast and easy.
It's really pretty straight forward and it came out perfect for me. I wouldn't have done anything different if I were to do it again.
Of course, I didn't have to worry about marring the paint since the dash is only in primer. However, had it been painted, it would have been fine.
I hope this will come in helpful to anyone considering this installation.
Edit:
After painting:
1 - 14 of 14 Posts
Very good Roger but you forgot something important... Measure twice and cut once:confused0006: Later, Dave
Very nice Roger, I like the vents in the dash. Later Bill
Looks great Roger. Where did you purchase the chrome vents and I assume the instructions came with them ? Lloyd
Also thanks much for the additional info on the installation and what you used. Great info.
You are welcome and thank you.
I bought them from here:
Pronesti Classics
Yes, they come with instructions. 2 pages that have a diagram for each side.
I was pretty sure that there was only one manufacturer of these, so I searched for the lowest price. I think a company called Unfair Advantage has them manufactured in China. This is the same company that supplies dash bezels and several other parts to Danchuk, Ecklers & etc. The quality seems really good and they have a superb fit to the dash. The vents moved around a little too easy for me but they are easily tightened by bending the wavy spring (that sits behind the ball vent) a little. It disassembles real easy by removing the lock ring on the front.
Thanks for the photos and the instructions, turned out great.
Otis :)
Looks like it came out of the factory that way :eek:
Very nice!!
I'm still trying to decide if I want to cut my dash, but after seeing how nice and clean those vents look I'm probably gonna go for it.
Thanks for the pictures and tutorial.
Geoff
Way to go Roger, they look great. I did my 57 that way but there was no pinch seam to deal with. The secret is a good hole saw.
Jim
Roger those look great. And sure look a lot nicer than the aftermarket under dash vents, which is what i`ll probably end up using on my 57.
A/C VENTS
HEY GREAT JOB ON THE VENTS. SO IF I INSTALL VINTAGE AIR IN MY 55 CAN I USE THESE? I SEE YOU BOUGHT THEM FROM GARY PRONESTI I KNOW HIM HE IS A GREAT GUY TO DEAL WITH FOR ALL YOUE TRI FIVE NEEDS.
JOHN:congrats:
Thanks!
Yes, you can use them with Vintage air. Their hoses are a different size than these vents on the back but they make adapters to connect them. Or, could just use duct tape.
Thanks!
On the 57 one side fits the VA the other needs an adapter. I cut down an ABS down spout from Home Depot.
Terry there are deals on eBay for the 57's, that's where I bought mine.
Jim
1 - 14 of 14 Posts
