hi, I'm new to the site I hope i'm doing this right I have a55 post car and I WAS WONDERING IF SOME ONE COULD EMAIL ME INFO onputting a 454 in my car I already have a turbo 400 in it dont know if it will just fit in or not without altering the fire wall or not or anything else? hope you can help!
Welcome. I believe you will have to do some firewall modifications in order to get a BB in your 55. That will mean either massaging your existing one or cutting it out and either building one or buying one of the aftermarket firewalls. Terry.
thanks for the info terry I talked to a guy in P.A he sold me motor mnts. that move engine foward enough to clear firewall thanks again!
Here is a picture of the motor mounts on my 454 in my 57 chevy
You can get them from several places, they move the engine forward between 3/4 and 1 inch for the clearance of the distributor.
Next you will need a spline/yoke from a 400 driveshaft, then you can get a universal ujoint that will make it bolt to you 55 driveshaft, although the driveshaft may need to be shortened.
next you will need to get a transmission crossmember for the rear of the 400.
I got mine from chevychevy.com , He does supply good parts at a reasonable price, here's what I got for my 57, give frank a call and tell him you need the setup for a 55
**1955 Side 1" Forward Motor Mount Brackets...$57.95 Pair
**1955 Custom Tube Cross Member With Mounting Brackets...$89.90.
And I suggest a radiator
**1955 V8 Or 6 Cylinder Set Up. 4-ROW Desert Cooler Radiator
Direct Fit. Bolt In JOB!!!...$254.95
I had mine polished top tank looks great.
here is a link to a yoke that will work off ebay
http://cgi.ebay.com/ebaymotors/Trans-Yoke-Turbo-400-3-3-2431x-1350-series_W0QQitemZ8070224966QQihZ019QQcategoryZ33738QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
lastly the ujoint can be purchased at autozone, I got one there a month ago.
I hope this help
Otis
Otis
I hope this help
Otis
Otis
Looks like you have a stock oil pan on your 454?
with those engine mounts, Does the oil pan clear the steering draglink?
You need to move foward more than 1 inch orr you will also need a large hammer, 2-2.5 is more like it. My 55 ha.d the 1 inch jobs tacked in whrn I got it and the heads would not fit on the dummy block. I built my own similar to those shown above.
hi ya and welcome! :)
me,
I'm not worried about the firewall...
cuz there is none... :D it was cut out years ago when the car was a straight axle gasser...
I now have a stock frame under it. and I'll build the new firewall around wherever the engine ends up.
was just wondering about that draglink/oilpan..
