Been waiting for a lot of new parts and most of them arrived today. Not that I really need them right now, maybe apart for the new rocker channels, but I started looking at the trunk hinges.
Just attached them temporarily using screws and will weld them later. Had to measure on the trunk lid the maximum opening between the bolts and minimum opening. This way I could figure out whether the trunk lid will fit to the hinges or not. However there are so much play in both the hinges and the attaching points that it probably is no issue.
Hope this statement will not bite me in my behind at a later stage......
However the max distance between the bolts I found was 1152 mm and the minimum 1132, all approximate measures. In addition there are play in the pivot bolts and the bolt holes in the trunk lid are over sized so again should not be an issue.
What is worse is that the lower attachment of the hinges towards the wheel well, a radius piece of sheet metal to be spot welded to the wheel well does not seem to fit well so I have to come up with a good idea to make it fit properly or at least attach it in a solid way. PO have replaced some patches of sheet metal in the wheel wells so I assume that he have not been able to duplicate the original piece. However I have seen pictures of several trunks where these are straightened and just welded solid to the wheel well so that might be the easiest solution.
No need for the original jack bracket so removed this.
Both hinges temporarily attached.
