56 bel air temp sender wire conector
320 Views 18 Replies 9 Participants Last post by  yellowtr3
sorry for another dumb question.
the temp sender has a strange, to me, wire connector terminal.
what does the connector at the end of the wire look like and whats it called and where to get them?
mine has just a spade connector that fits very poorly.
Frank
1 - 19 of 19 Posts
Frank
is yours the nail head type sender?? if so maybe this??
  • Like
Reactions: 2
if it's fitting that loose maybe that's your gauge problem??
Here is a link to a repair kit for your temperature sender wire and connector. The 1956 temperature sender is a one year only item and it should use the pin style connector. If you do not have the correct sender your gauge will not read correctly. I have also provided a link for a correctly calibrated 1956 only sender.
Steve
  • Like
Reactions: 1
that looks like it should work
thanks
Make sure you have the correct sender so you get an accurate reading.
  • Like
Reactions: 1
thanks
GM thought so.
  • Haha
Reactions: 1
what does the connector at the end of the wire look like and what's it called and where to get them?
mine has just a spade connector that fits very poorly...Frank
@acardon used to post a source for these connectors all the time...I'm not finding it now though.
That type of connector for the temperature sensor/switch is the same as the forward-end push on type and uses the exact same terminal inside. All that is needed "to make it work for the temperature sensor/switch is the little cut-out on the side of the connector housing so that can be installed from the side, sliding over the terminal tip on the sensor/switch. Not for the 1000pt restoration but it is equivalent. Those connectors may be available at the big box stores. I recently bought a new alternator connector - couldn't believe that I didn't have one. Working on some electrical presently. :)
  • Helpful
Reactions: 1
Tropturq has a good picture of the 56 ONLY replacement round post sending unit. The repair kit is for 57 and later. The connector will not work properly with the round post sender. Here is an original 56 water temperature sending unit.
While I'm at it, here is the difference between the original 57 water temp sender and the GM replacement sender.
Not only was the water temp sender post different but also the oil pressure sender post.
The plastic cover for the round post connector look like this.
The wire end is a wrap around that locks onto the groove on the post.
  • Like
  • Helpful
Reactions: 2
^^^ 1000% correct, took a look at my replacement (still in the box) and it does not have the nail head post, but exactly as above. What I said was related to the '57+ nail head style. Something else to change on my harness because it has the later terminal & connector on it. I'll probably use a round post push on type. My '55 is not original and I am using the '56 sender & gage setup.
  • Like
Reactions: 1
The temperature sender wire repair kit that I recommended in post #4 of this thread, includes both a slide on connector and a pin type connector. If you have the correct 1956 only sender it will use the pin type connector.
Steve
  • Like
Reactions: 1
I had a hard time finding the end connector and new sensor. I went ahead and just added a Mechanical temp
I have a '55 but will using a '56 cluster. I too have below dash gages, oil pressure and temperature from when I had the '55 bulb type gage. I just want the replacement '56 cluster to be fully functional too.
In my 55 I also put a 56 gauge in the cluster and matching sender. It closely matches the temp of my after market gauge temps. I've had this car 45 years and last year was the first year my cluster finally had temp readings showing. Love it!
what does the connector at the end of the wire look like and whats it called and where to get them? mine has just a spade connector that fits very poorly....Frank
Frank...I found this thread of interest: gauge cluster light sockets
The actual terminal that you need is called a "hairpin", and can be obtained from Rhode Island Wire unless you want to replace the whole wire.
  • Like
Reactions: 1
In the above figure with the sending units, the "56 series" refers to the terminal type - NOT the model year of the car.
  • Helpful
Reactions: 1
Exactly correct...The 1956 sender looks like this one
  • Like
Reactions: 1
Wow
do you guys stay up all night reading manuals?
laughing
you guys are so great
thanks
ill update you when my new/old gage arrives and i have time to test it.
my car is very original. some minor changes by the old owner when it was just an old car and not a classic.
trying hard to keep it original and return things that are not original back to how they should have been.
thanks
thanks
Frank
  • Haha
Reactions: 2
1 - 19 of 19 Posts
