Have an old, stock light switch from my 56 210. I'm trying to get that retaining nut off but, cannot remove the knob. I thought you just press the button underneath the switch to remove the knob? Will not budge!
What am I missing?
Pull the knob out all the way ( Lights on) , then press in the button and wiggle the knob/shaft out. You might have to try to pull the knob/shaft downward( raising the back of the shaft slightly) They are a p-i-t-a . :anim_25:
Mike,
Thanks for the tip! Yes, with a lot more persuasion, it came out. I think the trick was to have the knob pulled all the way out (on position) first.
Thanks again!...I knew it had to be something easy!
