1 - 3 of 3 Posts
My son is going to put this pan onto a '66 327. Since the original pan is deeper, does the pan require a longer pick-up from the oil pump? If so, where do we obtain the longer pick-up? Thanks
How much deeper is it you may be able to just add a extra quart of oil to make up the difference if not speedway summit and jegs should have what you need
The machine shop said the btm of the pick-up should be about 1/2" from the btm of the pan. The motor is yet together so I don't actually know the distance.
1 - 3 of 3 Posts
