You probably don't need new parts. Here's what to do.
First, inspect the striker plate. Clean it thoroughly, then re-lubricate the latching area with a THIN coat of white grease, like Lubriplate.
Now, inspect the wheel inside the latch on the door. Push the door handle button in, and rotate the wheel with your finger. I'll bet it's sticky. Spray a bit of carburetor cleaner up in there around the shaft (mask off around it if you have nice paint) and get it spinning easily. Then, put a little shot of spray lithium grease on the shaft. Then, clean the teeth on the wheel and put a light coat of white grease on the teeth.
