1 - 12 of 12 Posts
Changing out the gas tank and lines on my 57, Not sure if this is the right forum for this question but here it goes. I bought the kit from Ecklers with tank, sending unit , oring gasket, etc... The 4" estimated hose length and around 1-3/4" diameter that connects the 2 filler tubes to put fuel in the tank was brittle and cracked. I can order one from Ecklers for around $25. Does it have to be a special hose? Could I use use a section of a radiator hose with the right ID? Probably cheaper and I don't have to wait a week or more for shipping.
Thank you,
Try ol 55 east coast chevy. they have two alternatives, one a reproduction and the other a replacement, specific for the application. One costs less then the other. You don't want a non gas contact line shedding little pieces of rubber into your tank and clogging up the works. Also, if the tank came with a rubber gasket for the sender, throw it away and get a cork gasket. The o ring you got may or may not work. Its sort of a crap shoot when using a repro tank and original fill tube. Play it by ear. Some have been too loose, and others too tight.
Do a search on this site for gas tank installs as there are a couple of things you should know, mostly about the pick up and getting the fuel lines on the pickup including using the correct copper washers for the pick up.
Thanks!!!!
Thank you,
I don't remember seeing a hose on mine...Just a solid pipe with an O ring...What model do you have?
Seems I remember the 57 having a hose. Just go to an industrial place that makes hydraulic hoses and they will probably have a scrap piece they will sell you. It for sure will be fuel proof.
'57 passenger cars have a vent hose connecting the tank to the upper fill tube, and a larger short hose connecting the upper and lower fill tubes together (and an O-ring where the lower fill tube fits into the tank).
They must be able to handle repeated contact with gasoline, so I wouldn't consider using radiator or heater hoses.
I stole this picture from the Speedway Motors web site:
Marine grace fuel filler hose. It’s the correct size, it bends nice without kinking, and it’s designed for fuel. Hydraulic lines are not.
1 - 12 of 12 Posts
