57 210, 2Dr wagon
will rear doors from a 4 door sedan fit on a wagon if the window frames were swapped.
to gain the "kink" body line that the wagons don't have.
thoughts???
1957 Belair wagon, 51 HenryJ
Yes they are the same door, just look inside at the inner framing. A fellow said he did that in the 70's to change the look. The trim below the window on a B/A sedan is different from the wagons so you will have to use 210 SS there. Good day.
It will be a lot of work to make the Sedan doors fit a Wagon. I mean by cutting, then welding the upper part of the doors so you now have the Wagon window frame on the Sedan door.
Just wondering if it might be easier to cut and slice in the upper part of the Sedan door to the existing Wagon door? So the dip in the sheet metal could be grafted on.
57 210, 2Dr wagon
I actually was thinking of trying to a 150 4 dr. wagon.
and being able to use 57 4 dr. 150 trim.
need to find some donor doors.
57 210, 2Dr wagon
will do with the pictures, but this is way early in the planning process.
got a bunch of tools that I need to learn how to use. :confused0006:
