1 - 3 of 3 Posts
I rebuilt the front end of '57 Chevy using the 2 deg. offset upper a arm shafts.
Couldn't get allignment to recommended specs. Found upper a arm bushing hit frame before shaft was against frame.Now I am not sure if the upper shafts are installed correct. Also the lower shafts are supposed to be different from side to side.
How do I tell which goes where and facing which way?
Any help??????????
member
Welcome!
As I recall they are different from side to side. This has been discussed quite a bit before...try a search if someone doesn't answer it or provide a link.
1 - 3 of 3 Posts
