1 - 12 of 12 Posts
Trying to hook up a temp switch for my electric fan. Nothing is simple as my new intake did not have enough ports to install switch. So after reviewing my options I bought an adapter plate with 2 ports that mounts below thermostat housing. While I was at it installed new thermostat. First thing I found is that O ring on old housing was shot so off to NAPA and bought oring for a Ford which seemed to fit. Scraped off old sealant and lightly sanded around thermostat opening and no leaks which surprised me.
Waiting on switch ( none available locally so ordered from Summit ) so put in plugs for now.
As usual, simple project took most of the day.
Larry
Larry, You might do yourself a favor and toss that chrome T-stat housing in the trash where it belongs. It may not be leaking now but it WILL leak and most likely while you are out on a trip somewhere with the 57.
Got it Bruce. Thanks for the advice.
Larry
Denver, Colorado 1956 Nomad
Hopefully, you won't run into interference problems between the sending unit and the bottom of the thermostat.
I see what you mean about interfering with thermostat. May have to move heater hose to spacer and switch to manifold. Would need a fitting to go from 3/8 NPT to heater hose. This means I gotta take it all off again and turn the spacer around with ports pointing to the front. Grrrr! Wonder if I can find a fitting to go between the spacer and switch to allow it to not interfere with thermostat?
Thanks for the heads up.
Larry
Edlebrock manifold Larry?
Why not use the port built into each head? I like those head ports, and they eliminate wiring running up to the intake manifold.
Discussion Starter · #12 ·
Yes Edelbrock intake. I don’t have ports in my heads. 291 camel hump heads.
Larry
1 - 12 of 12 Posts
